Code p0446
Old Feb 14, 2024 | 02:46 PM
ericp1969's Avatar
ericp1969
3rd Gear
Default Code p0446
So been doing some research on this code and seems to be related to valve pressure letting gas fumes out. Let me ask, so I have a 2019 z06 and when I am pumping gas, the pump will stop intermittently I am wondering if something there is causing the code to come up. could it be the corvette gas funnel which has no cap now broken somehow? Does anyone else have this experience? Thank you in advance
Old Feb 14, 2024 | 03:26 PM
Track's Avatar
Track
These cars have a restrictive filler pipe, so they frequently kick off the gas station pump. That is a function of the sensor on the pump nozzle. Your P0446 is a problem with the fuel tank vent system...unrelated to the gas station pump kicking off.
Old Feb 14, 2024 | 03:38 PM
Thomasmoto's Avatar
Thomasmoto
Both of my Corvette's do that. it's just a little aggravating. Sometimes I rotate the nozzle up 180 and it seems to do a little better. So I don't think that would cause that code.
Especially when filling up with E-85. Since it's cheaper the pump runs a little faster.
Old Feb 15, 2024 | 10:20 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
This is certainly not what we like to hear, ericp1969. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Corvette Z06. To do so, please send an email to socialmedia@gm.com with ATTN: ericp1969/Corvette Forum in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Old Feb 15, 2024 | 11:55 AM
laserdude2215's Avatar
laserdude2215
The Evaporative Emission Vent Valve is located forward of the right rear wheel well liner. Check for a blocked or kinked hose.
Old Sep 18, 2024 | 09:11 AM
Bruceham's Avatar
Bruceham
I'm seeing the dreaded "P0446" pop up every time I drive now, but I haven't had time to troubleshoot it.
One other symptom I've been experiencing concurrently, is the fuel pump nozzle constantly clicking-off when putting gas. I don't mean clicking-off 2 or 3 times like it normally does. It is clicking-off 20 times or more, very annoying, and then the tank is not even full. There must be a restriction in fuel tank ventilation.
Since I'm on the topic, I have to also gripe about the fuel door lock. Maybe 4 years ago or so, I pulled up to the pump and the freaking fuel tank door would not open. Had to drive home on fumes. Curse you GM !!! Somehow I was able to bend the latch so it no longer locks.
Old Sep 18, 2024 | 07:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With the P0446 you have either a bad vent valve (normally open) and if stuck closed you will have issues filling your tank…this may also be a restriction or blockage in the vent hose….you need a bidirectional scan tool to accurately diagnose this.
Old Sep 18, 2024 | 08:12 PM
Bruceham's Avatar
Bruceham
Thanks, I was able to run my X-tool scanner this afternoon. The fuel tank pressure sensor, vent solenoid, and purge solenoid all seem to be functioning properly. The code is only thrown when you get down on the gas, leading me to think that a partially clogged Canister Charcoal Filter might be the culprit. This Saturday I'll remove the wheel to do some troubleshooting. In the meantime I ordered the vent solenoid and Canister Charcoal Filter. Will post an update next week.
Old Sep 18, 2024 | 08:17 PM
C5 Diag's Avatar
C5 Diag
If the vent valve is OPEN with ignition on you will see 1.5 volts on your fuel tank pressure sensor data PID…1.5 volts is atmospheric pressure.
Old Sep 23, 2024 | 08:43 PM
Bruceham's Avatar
Bruceham
OK guys, I replaced Evap. Charcoal Filter Canister ~$180.00 and the Evap. Vent Solenoid Valve ~$23.00, and it fixed the problem.
Yea, not even one click at the gas pump. However, the dang tank now took 17 gallon from empty, I'm not exaggerating. Before, the most it would take from empty was ~13 gallons - weird .
Old Sep 23, 2024 | 08:48 PM
C5 Diag's Avatar
C5 Diag
Cool and I’d stop filling the tank when it first clicks off…it’s when you overfill the tank you start having Canister issues.
Old Sep 23, 2024 | 08:57 PM
Bruceham's Avatar
Bruceham
Duly noted, that's what I did. No more trying to wring out that last drop .
To Code p0446
