Do you think the ZR1 wing will retrofit?
#202
#203
#204
I am pretty sure they are standard 6mm bolts.
These would probably work. I cant remember the length of the bolt GM bolt,.... these are 25mm long. You can also get 30mm long
https://www.mcmaster.com/91292a138 - 25mm long bolt
https://www.mcmaster.com/91292a139 - 30mm long bolt
If you have an Ace Hardware locally, they might have 6mm stainless steel bolts readily available as well.
Poor-sha (07-09-2019)
#206
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
#207
Mine arrived via FedEx and required a signature. I did receive a notice once the tracking number was issued that informed me of the signature requirement.
#210
#212
I have completed my wing installation.
Supplier: Weapon-X Motorsports
Parts Installed: ZTX Wing ZR1 Style, ZTK High Wing Brackets, and ZR1 Style Body Wing w/ Brake Light
Many thanks to Ben, Kent, Brent, David and others at Weapon-X for making this addition possible.
#215
Is the ZTX wing an exact mold of the factory wing, and are the 2 AoA settings identical to those of the factory wing?
#216
#217
Thank you guys for this. I will attempt to it tomorrow. Im supposibly #5 on the waiting list. I placed my order april 30th. Both body wing and high win, not the XL one.
#220
My order was entered on July 8th, I received an update today that I am #14 on the list. The estimated completion is around end of August or early September. (ZTX Wing and Factory ZTK Height Brackets)
