Randy Pobst is tearing up Willow Springs!
#201
Well I like Porsches ( and I have owned a 911 Carrera now a C7 Z51) and consider that the Corvette Grand Sport is a very balanced sport car that would go head to head easily VS a 911Carrera S.
#202
Your carrera s is a full 300 lbs lighter than GS. That is A LOT considering GS only makes 40 hp more than 911’s 420hp.
#203
Are you sure about that? I don't believe that's possible, even with massive downforce. Taking turn 1 flat in that car would mean going probably 160 mph. The track record as Willow is actually a lot quicker than 1:13.
Radicals are neat, but they aren't street cars, even if in some countries they are street legal.
#204
too heavy for a true sports car. 3700 lbs is too much. I would argue even 3400-3500 lbs is too heavy. People who arent bothered by this are in a very different demographic/culture bucket and buy these cars for different reasons.
poorsha’s videos as well as Randy’s own videos all show massive mid corner stabilization issues where the car becomes very hard to control when the driver gets on the throttle. Watch those videos please. Then watch porsche’s gt3 or gt3rs videos in same tracks (randy has gt3 videos) or in nurburgring. You can see that you can go wide open much easier and car is much easier to manage.
this is all a problem because of the weight. If the car wasnt 3700 lbs, then chevy wouldnt need to add 757 hp to counter the weight. This is not a problem for 80% of the corvette owners who are (like many other american sports car buyers) care more about drag strips (well such thing called drag racing strips only exist in america like shooting ranges in every corner) than going around corners but I am the other 20%. Sure you can have people like poorsha who track a corvette but i’d argue thats like having an x5 to do offroading instead of a wrangler rubicon. I dont think we will ever see a corvette ever truly beat a porsche. Truly beating will mean beating it in scales, in handling, in speed, in braking, in looks, in everything. Corvette does 2 things right 8 things wrong. Its a compromise car.
Which was fine until they started charging as much as a gt3....
#205
The ZR1 literally has more than double the torque. You can't really make a valid comparison of stability while putting power down especially when comparing the precise throttle respone of an NA motor to an FI motor. Not to mention the ZR1 is much faster, when you are going faster, you break loose quicker which requires quicker responses. I've watched poorsha's videos, car seems very manageable. I've also driven C7Z's on track and they are smoother and more confidence inspiring that any GT3. The wheelbase advantage of the C7 can be felt easily. If anything, heavier makes inputs and reactions slower and easier to react to. It's harder on tires, brakes, equipment and causes heat build up, but the weight isn't making the car unstable, if the car is unstable now, it will be worse at a lighter weight. Putting down 700 ft lbs on corner exit is no small feat on street tires. If it were lighter it would be worse.
ZR1 is not much faster. ZR1 is faster in a straight line. It is substantially slower leaving a turn or during the turn. The MT test indicates this. Take a look at it yourself. The fact that GT3RS did what it did with 250 hp less and HALF as much torque proves my point.
Every PDR recording of Z06 and ZR1 in the hands of a good driver has the same correcting mid corner action where the driver applies gas and the rear end lets go and you have to fight back. This is not normal or more importantly not an ideal behavior. You might like it or might be used to it but it means car is not well
balanced and engine overpowers the chassis.
And you could not have been more wrong about GT3 being more difficult to control. Every journalist and car enthusiast, including those who have driven GT3s and corvettes (who also own either) will agree that GT3 is far easier to drive at the limit due to its weight, power, rws, pdk, and size advantage. Saying that does nothing but destroys your credibility.
#206
There are no pros to having additional weight only to be countered by more HP and TQ. As you stated, this accelerate wear on tires, brakes and other equipment that is now stressed to a higher degree with additional weight.
The Camaro ZL1/1LE is a perfect example. The car has a lot more HP and TQ than a C6Z Z07. It also has stickier tires, way better suspension, aero but carrys a lot more weight (500lbs+). Yet the C6Z Z07 is there with it and I bet the C6Z is a lot easier on it's consumables and components. http://fastestlaps.com/tracks/laguna-seca-post-1988
As other manufacturers are reducing weight for their track models, Chevy is going in the opposite direction by continuously adding more weight to their cars. As the Corvette keeps going up in price, the bang for buck argument also starts to fade.
Team Corvette needs to go back in time and remember what made the C5Z/C6Z great in the first place. It wasn't the gimmicks. It was a well executed balance of weight and power available at a reasonable price.
#207
A fair argument can be made that all that HP and TQ isn't necessary if there isn't additional weight (and drag) to deal with. We also don't know where the weight is located on the vehicle and thus it's impact on handling.
#208
Before we lose sight of the origin of the arguments let's try to remember that we are all here on this forum section because the C7 ZR1 is (relatively) AFFORDABLE. GM could have made a lighter, faster ZR1. It would have cost more. They prioritized a budget far out of step with exotic cars and did a commendable job of building a car that is not quite as quick as the some costing 3-10x as much, but is more accessible (production time) and more practical.
The following 2 users liked this post by Palantirion:
desmophile (07-09-2018),
jim2092 (07-08-2018)
#209
- There is one pro: cost.
#210
Thanks! ;)
The Camaro elsd is completely different. They basically took the rear diff axle assembly they already had and changed from the Eaton Detroit Truetrac mech diff to the Eaton IntelliTrac elsd diff. So basically they swapped out the parts in the pumpkin and added controllers and programming. The controller and programming looks nearly the same as C7, but the mech parts totally different.
Anyway, I was and with your info still I am guessing the unit itself just works better.
After all, the Corvette unit originated GM's eLSD usage as I understand it.
Another reason for the C8's Planned release.
#211
I sincerely disagree. Open your eyes. The ZR1 and equally optioned GT3 are virtually same price. In the hands of you, me, or any other average forum member, we will be within a second of each other in any track in GT3 and ZR1. Period. ZR1 is not the bargain $50,000 stingray was. ZR1 is SLOWER than the $180,000 GT3RS. Where exactly is the bargain here? The closest more expensive performance cars in the $200,000-$300,000 range are 720s and GT2RS and they are SUBSTANTIALLY faster than ZR1, both in straight line (almost 10mph trap) or in a track (2+ seconds in a short track like willow). So again, where is the great bargain here? Where is the super car killer? It barely makes a super car itself considering the new M5, A BOAT, does the same 0-60 and 1/4 mile times.
Newton06 (07-11-2018)
#212
I think you are missing my point. Of course it is hard putting that much power down. But zr1 has that much power and torque in the first place BECAUSE it weighs 3700 lbs. if it weighed 3150 lbs, it wouldnt need that much power. Having that much power is useless.
So now knowing this, why would GM invest what would amount to many more billions using exotic materials and pushing the price of the base vette into the stratosphere? The Corvette is a budget minded supercar. Maybe less so than before, but still budget minded, with all the new gadgets and required safety gear that are driving the weight of all cars up. It's not worthwhile to please a few guys on the internet, while the ZR1 does 1:26's at Road Atlanta and 1:51 at VIR. If you had any idea how fast those times are, you wouldn't be spending so much time complaining. You would have a hard time finding fully race prepped C6Z's that can do those times. The C6Z was relatively light at 3200 lbs.
Evolution is evolution, GM is catering to it's primary audience and making a car that produces staggering times for a cost that's beneficial to them. There have always been compromises, in every generation. This one is no different.
I'm just going to sit here and wait for one of you guys to run faster times in your previous generation Corvette's so we can see how backwards GM has gone.
The following 4 users liked this post by heavychevy:
#213
#214
Open your eyes lol, "the ZR1 and equally optioned GT3 are virtually same price" you are joking right, just tells me you never bought a porsche, almost no porsche buyer buys the car without any options, the options make the porsche much more expensive let alone in the GT3 and RS ones there are significant markup, that's just how these cars work.. considering the hp and tq plus other performance figures the ZR1 offers, the ZR1 is a bargain because its rivals are expensive high hp cars, also you should start comparing cars at the same price level and you would notice how much the ZR1 offers. Porsche is a car of balance, many more expensive/high powerful cars are slower than the GT3RS, so pointless on just taking it on the ZR1 and unfair as well since the key point of focus in building these cars are different, one is aiming more in power and one has a history of focusing on balance and aero. Plus there is no clear winner in cars nowadays or how one car is just 'better' than the other, performance cars these days are engineered very well, each have their uniqueness to offer, buyers of the ZR1 are those who can appreciate the ZR1 and corvette's heritage, 911s have their own charm, lamborghini gives you that violent kick in the back, ferrari is about the feeling, etc... each of the cars have their differences in engineering that also offers world class performance, that's what makes up our car culture and what makes it so fun and addicting. How you judge and compare cars is ridiculous, shows how you don't understand cars, like why would you even compare a M5 to a ZR1, cars are not just about numbers and how fast they go in a straight line unless ur a 12 year old kid that thinks straight line speed means everything.
A base 991.1 GT3, fresh from factory can go head to head with z06 and 991.2 can do the same with ZR1. 991.2 GT3RS is faster than ZR1 although not by much and GT2RS is substantially faster than ZR1.
#215
How porsche buyers buy their cars have very little to do with how a car optioned just enough to perform well performs. You dont need a single option on a gt3 to take it to track to get the times posted by magazines. The same isnt true for corvette due to their tiered packages.
#216
CPhelps (07-09-2018)
#217
I was thinking the same thing.
The SC2-R on the GT2 seem to hold up fine.
My SC2 on my Grand Sport had the same exact issue at 50 degrees.
#218
Key words - AT THE LIMIT. Higher Limit, twice the torque, FI is going to be harder to control. This is a matter of fact. I didn't miss any points. Your argument simply is not plausible. The Corvette demographic does not support a more barebones, exotic material lightweight frame while still maintaining a bigger wheelbase vehicle. The average age of the Corvette buyer is fairly high, most want a weekend cruiser to drive slower than the speed limit. Not to be dicing it up on the track. That is a relatively small percentage of those who will be owning a Corvette. Even for the ZR1, more will be garaged and babied than driven any where near the limit on a track. GM knows this, really anyone who pays attention and goes to the track knows this.
False, the additional weight serves to keep the price down. If you have ever tried to lighten a vehicle, you realize that once you get past the obvious stuff, it gets REALLY expensive. Factory cars are no exception to this rule. Once you start using lightweight materials, price goes up real quick. The ZR1 still has all of the amenities. They don't seem to have wanted to make a barebones ACR clone.
#219
People seem to miss the fact that faster doesn't necessarily mean more fun. Most of the time it means less fun. It's why people love Caymans and Miatas and S2000s.
#220
Not entirely true. You can make a car lighter, and less expensive. First you have to make the car SMALLER. The C7 is too big, too heavy, too long, too wide. My FR-S is simply more enjoyable and fun to drive, then my 500hp C5. Not faster, although with equal tires, it would beat my C5 around road course like Barbers.
Edit: are people in here seriously making the argument that the corvette needs to be more like slow, light weight cars? You must have forgotten the heritage of the Corvette..or that the same chassis races on the weekends. Lol.
GM may never built a track monster like this again if thi is the response they get. Waxers complaining about the wings, and now wanted something more like a miata. You guys can't be serious.
rikhek (07-18-2018)
