C7 ZR1 Heat Issues Thread - Let's get into this!
#41
Ahhh I see, difference is a quarter inch. ZTX is what I've adopted for our kits, but isn't specific to ZTK cars. So, stage 1 is quarter inch spacer which just reduces the heat to the lid via conduction. Stage 2 is .5" and will include the WEAPON-X vented cowl for clearance and heat extraction for max cooling efforts. I cannot wait to test the latter based on the heat suffered by the OEM cowl.
#43
St. Jude Donor '14
Update:
Starting to make some progress on a few things!
Vented cowl features slightly taller lid for our lid spacer which just continues to show phenomenal cooling capabilities:
#44
Outstanding read and analysis Ben. Thank you for providing these solutions instead of settling on "that's good enough".
Ben@WeaponX (11-30-2018)
#50
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
This is disapointing.....
It's disappointing to hear that this bad boy C7 ZR1 is having heat issues. One would have thought GM would have had this worked out a long time ago. I LOVE this car and plan to own one sooner than later. As I won't track mine that often I guess its nothing to be that concerned about (and I would probably get mine with the Manual Tranny anyways).
#51
For what its worth my ZR1 oil temp runs around 200 -210 most of the time in same driving + ambient temp conditions that my wet sump C6 Callaway SC606 GS convert is running 220-230.
#52
St. Jude Donor '14
Yes it is def improved, even over the past C7s!
Mopar Jimmy (12-03-2018)
#53
You say you are passinonate about your work and it clearly shows in your posts.
These qualities in turn are a great benefit for your customers.
Thank you for your admirable contributions!
Ben@WeaponX (12-02-2018)
