C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
It's Delivered, Driven and Modified...Initial Thoughts
Old 10-05-2018, 10:42 PM
Ben@WeaponX
Ben@WeaponX's Avatar
St. Jude Donor '14
Originally Posted by Bob U
Was this with the stock thermostat?
yes
DocScott (12-02-2018)
Old 10-06-2018, 12:23 AM
chubbs6350
chubbs6350's Avatar
Originally Posted by Ben@WeaponX
Not to me, boost is irrelevant because the cars aren't the same. I can put these same mods on a Z06 and you're still down 100 HP, just like the OEM BHP
But you do bring up a good point though because the Z06 puts down about 10-10.5 PSI we see at 20k blower RPMs making 650 BHP. ZR1 puts down about 14 PSI at 16k blower RPMs making 755 BHP. The ZR1 blower moves about 50% more air per revolution than the Z06 blower; however, with 4k blower RPMs less, the car makes 4 PSI more and 105 BHP more. It just goes to show you, there is a LOT more on the table once you get in. I've ran nearly 20* and an extra 3 PSI to make my 800whp and this is not "fine tuned" by any means LOL. I've tested a lot of what we call in-house "f*ckery" haha playing around with this.
Mark my words, when we get access, this blower setup will make 1000whp with heads/cam/E/ported blower/20 PSI and I have the parts sitting here waiting and going to test our dimple ported (think golf ball) heads since they really shine with port injection to reduce the port wall drag.
I have enough head room at the moment to port the blower, so that might be happening very soon as is too.
Wow gm didn't mess around with this blower! It should stay much cooler then too. Thanks for info, I'm excited to see what you can do with that beast!!
Old 10-08-2018, 09:20 AM
Dan Massie
Dan Massie's Avatar
Originally Posted by pibohmark
Took Delivery of #1057 after what seemed an eternity!
I did notice that when driving in the sport mode the exhaust when not under acceleration load seemed to revert to "quiet" mode until I would accelerate and then would return to its throaty roar. There is a setting the guys at Weapon X showed me that you can open the exhaust to "Track Mode" manually to alleviate this.
Even in track mode, it will still go to quiet when you aren't pushing it.
Old 10-08-2018, 10:01 AM
fatsport
Support Corvetteforum!
fatsport's Avatar
So how can this car be bumped 10-12 % on stock tuning and not be lean?
Tuners claim over and over that the Z06 and Stingray MUST be tuned if they increase power, yet vendors are putting long tube headers, cold air and pulley on this and not tuning it.
Who's full of crap?
Old 10-08-2018, 10:47 AM
pibohmark
pibohmark's Avatar
Who's full of crap?
I am at my dealership now, and getting the 500-mile oil change done. Diagnostics were run and they show no lean events. I think it would be safe to assume that the computer adjusts by enrichening the air/fuel mixture as it would with density altitude or ambient temperature. Also getting track alignment done today and will report back if it has any effect on wandering sensation. It's not unheard of for cars to be out of alignment from the factory.
Old 10-08-2018, 11:13 AM
fatsport
fatsport's Avatar
Thanks for the feedback. Beautiful car
Old 10-08-2018, 11:40 AM
3 Z06ZR1
3 Z06ZR1's Avatar
Originally Posted by JMB
Congrats!
Please explain how your car has more RWHP than the 755 FWHP that the car comes with? The SAE RWHP for a stock ZR1 should be in the 650-670 range depending on A8 or M7.
610-660 range rwhp out of the box is what I have been seeing here in threads.
Old 10-08-2018, 11:53 AM
3 Z06ZR1
3 Z06ZR1's Avatar
The 2,65 moves about 34 percent more air than the 1.74 and about 13 percent more than the 2300
Old 10-08-2018, 12:04 PM
3 Z06ZR1
3 Z06ZR1's Avatar
Sweet car and sweet results sounds like the car adjusts for the intake and light mods.
Like the Z06 gets a big gain from a certain intake.
What fuel are you running learned that the fuel makes a big difference as well.
My 673 on 92 goes way up when you add 100 octane or a few gallons of E85
to premium unleaded
Now the naysayers will come up with car relearning the mod out like they did on the Z06 which is wrong.
I do think your warranty is gone when the dealer sees the pulley swap thought.
Old 10-08-2018, 01:08 PM
pibohmark
pibohmark's Avatar
So far just Sunocco 93 I will be putting the car on the track at Barber in November then Daytona and will go 100 octane there. Pully swap according to district service rep would only void the warranty if drive ratio were changed. This pully is simply grooved for less slippage.
Old 10-11-2018, 09:28 PM
danm1
danm1's Avatar
Default Diffusor
Where did you get your Diffusors? I got mine on Ebay. They fit nice and really add to the back profile of the car. It should have come like this from the factory!
Old 10-11-2018, 10:49 PM
Newton06
Newton06's Avatar
Something doesn't seem right here.
100+ HP with the simple bolt-ons and no tune???
No increase in boost, no LT headers, just a ported TB, an intake tube, an an x-pipe, and a grippier upper pulley...???
You cannot get this kind of power out of a Z06 without headers, more boost, and a tune unless you do a H/C package.
Old 10-13-2018, 09:28 PM
  #33
Ben@WeaponX
St. Jude Donor '14
The Z06 reference is somewhat irrelevant since the superchargers are completely different; however, these are about the same results I got when we did mine!
https://www.corvetteforum.com/forums...hp-716wtq.html
Old 10-25-2018, 10:59 PM
  #34
Ben@WeaponX
St. Jude Donor '14
Default Mark M's C7 ZR1 graphs vs. mine
I told you guys I'd get this off the tower with the numbers, so here was Mark's baseline with 300mi vs. his X850 package:
And this is what is the most interesting. This is Mark's X850 package vs. mine. As you can see, this package is no "fluke" as these two cars were nearly identical on power AFTER the mods, but the interesting part I wanted to point out is Mark's ZR1 put down about 670whp with 300 miles on it, and mine with 800 miles on it put down around 690whp?! After the mods, they were the same, so I am wondering if his car broke in on the dyno at WOT after a few pulls with the rings seating more or something because when I saw how much less his car put down on the baseline, I'm not going to lie, I was worried my car was a factory freak and he was going to be disappointed by my claims. But she did exactly what she was supposed to do!
Any of you guys interested in coming in for our ZR1 packages, hit me up!
The following 2 users liked this post by Ben@WeaponX:
DocScott (12-02-2018), WzUpDoc (10-26-2018)
Old 12-02-2018, 05:30 PM
  #35
MCK_Z06
MCK_Z06's Avatar
Originally Posted by txoutdoors
Just ordered the parts I needed to complete Ben's X950 package. Already had the CAI, throttle body, and intake tube installed. Plan to dyno with existing mods and again after the install of the remaining parts. So excited (especially after seeing this post!) to see the end numbers. Very happy with the Weapon X parts already installed. Will post the video when done.
To the OP - congrats on the car and upgrades. Yours is identical to mine.
I saw your car last week when I was up at 21st Century Muscle Cars looking at the progress on my car.
The numbers it made with the throttle body and intake tube are pretty crazy for a stock engine and tune.
I'm curious to see what it makes with the rest of the Weapon-X package installed.
Ben@WeaponX (12-02-2018)
Old 12-02-2018, 08:16 PM
  #36
2019ZR1GreyGhost
Cruising
2019ZR1GreyGhost's Avatar
What is an A8 car making with the same mods Ben?
Old 12-02-2018, 11:00 PM
  #37
MCK_Z06
MCK_Z06's Avatar
Im pretty sure this was an A8 and it made 700whp. (I forgot the torque.)
For comparison on the same dyno, we threw every trick in the book at my M7 Z06 including heads and cam (but excluding E85 & Meth) to break 700whp on 93 pump gas.
LT4's don't respond to an intake and TB like that with a stock tune for sure.
Old 12-03-2018, 07:36 AM
  #38
robertbruce
robertbruce's Avatar
Received 3,222 Likes on 1,580 Posts
Nice car!
Quick Reply: It's Delivered, Driven and Modified...Initial Thoughts
