Katech builds the first 1000+hp LT5. Dyno video inside
Premium Supporting Vendor
Wow. That is insane. You'll be able to spin the tires all the way from one corner to the next.
Lavender (01-08-2019)
Moderator
Wow, all bolt on and no tune.
Pro Mechanic
Pro Mechanic
Exactly how we are controlling the engine will remain proprietary at this time. We do have control of the calibration using this method so it has been tuned.
The industry standard for engine dyno is STP. We showed SAE for the baseline to have a direct comparison to the 755 SAE factory rating and directly compare the increases due to dyno headers, air filter, and calibration.
For comparison sake, what were the STP numbers for the baseline? SAE was 788/762, this would convert to what in STP? That way we can see the increases of the first mod using the same correction factor.
I'm not trying to be a "Richard Cranium" here, just wanted to see the increases using the same correction factor........
thanks jason,
for comparison sake, what were the stp numbers for the baseline? Sae was 788/762, this would convert to what in stp? That way we can see the increases of the first mod using the same correction factor.
I'm not trying to be a "richard cranium" here, just wanted to see the increases using the same correction factor........
826/795.
