C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Homemade jack pucks
Old 02-15-2019, 08:33 PM
Rinaldo Catria
Rinaldo Catria's Avatar
Default Homemade jack pucks
I made jacking pucks for my C6 with eye screws and hockey pucks. Im thinking the ZR1 aero needs more clearance. anyone out there double up the pucks (screw or bolt them together). Is the keyway slot in the chassis the same on a c7 as a c6? Or suggestions for ones to buy and where. Thx.
Old 02-15-2019, 09:31 PM
Mr. Gizmo
Mr. Gizmo's Avatar
don’t know specifics regarding the zr1 aero but I made a set exactly as you describe for my c6z06 and they work just fine in my c7z. The slots they fit in seem to be in a similar location on both cars.
Old 02-15-2019, 11:25 PM
Jeff V.
Jeff V.'s Avatar
Received 4,086 Likes on 1,971 Posts
I've had no problems with single pucks and full length side skirts on my Z51. I don't think the ZR1 is any lower in that area. I can get my Quickjack with the rubber blocks and the pucks under the car just fine.
Old 02-16-2019, 03:30 PM
Rinaldo Catria
Thanks for the replys guys. Car is stored back in U.P of Michigan and I want to be ready when I get home from AZ. Might be a while. The snow is piled up waste deep back there.
Old 02-16-2019, 03:42 PM
UnhandledException
UnhandledException's Avatar
Received 1,351 Likes on 554 Posts
I was going to get one of these, does anyone have any experience with them?
https://zl1addons.com/collections/co...jack-lift-pads
Old 02-16-2019, 05:21 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,148 Likes on 601 Posts
Reverse Logic makes double thick, Delrin jacking pucks. I use them on my 2012 ZO6 all the time.
Old 02-19-2019, 08:44 AM
Zjoe6
Moderator
Support Corvetteforum!
Zjoe6's Avatar
Received 3,941 Likes on 2,427 Posts
Yeah those double thick will clear anything.
To Homemade jack pucks
Quick Reply: Homemade jack pucks
