C8 ERay/GSX/ZR1X ERay/GSX/ZR1X Discussion
Sponsored by: Vibe Motorsports
E-RAY first feedback
Old May 10, 2024 | 10:58 AM
dw886's Avatar
dw886
Originally Posted by March
Thanks - seems a bit odd that I can drive away without a seat belt in normal or shuttle mode.
According to the TechLink article here (https://gm-techlink.com/?p=18502), the following conditions must be met to enable stealth mode:
  • Doors closed, seat belt buckled and brake applied.
  • Outside air temperature greater than 50°F (10°C) as determined by the vehicle.
  • High-voltage battery greater than 28% displayed state of charge.
  • 12v battery greater than 65% state of charge; this parameter is not displayed in the vehicle.
  • 12v battery temperature greater than 41°F (5°C); this parameter is not displayed in the vehicle.
  • Parked on a grade less than 12%.
  • Fuel level greater than 8%.
Old May 10, 2024 | 11:06 AM
GM MUSL's Avatar
GM MUSL
[/list]
Thanks for the link. There are some things I did not know about.
Old May 12, 2024 | 07:24 PM
DIPPOLD's Avatar
DIPPOLD
Yes, they are the Pearl Nickel. However I am thinking of having them turned into Black Chrome by Wheel Craft.
Old May 13, 2024 | 01:14 PM
GM MUSL's Avatar
GM MUSL
Default ERay underbody strikes
My Dealer installed 2 underbody strikes and possibly removed the Stall Gurney Flaps from the front wheel The track prep guide does not indicate the Strikes are to be installed in any case. I think the Track Prep Guide is Wrong. I have the ZER package and no front splitter. What do you other ERay owners with the ZER package and no spitter have on you car? Here is the Track Prep Guide link https://redirect.viglink.com/?format...uide_Final.pdf
One strike on each side installed.
Old May 13, 2024 | 03:50 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by Bob MacLean
For the OP. That is the procedure that is in the Owner's Manual FOR TRACKING. GM refers to it as burnishing. But if you Google to find out more about what it does and why needed, most folks use is the word bedding. So that is what I use.
Unless you are at a Track (and even then) hard to find a place to perform the several 25 times braking procedure from high speed and required cooling without stopping. Also for street driving no need to get the brakes as hot as the Track procedure will produce. In street driving you will never get that hot. The key thing you are trying to do is get a uniform layer of pad material on the rotor.
This is what I used on my E-Ray and now get "good" stopping with pads at room temperature to "great" when warm and hot..They will never get to a higher temp that they did with my procedure than they achieved with my "bedding" procedure then will see with my aggressive street driving:
  • First, as the GM procedure notes, can skip Step 1 IF you have >200 miles.
  • So, with high spots probably worn-in I started Bedding with ~200 miles in a modified Step 2 + 3 with Cool Down.
  • Found a ~15 mile long two lane road with few intersecting roads so few cars entered.
  • I applied the brakes aggressively from 60 mph to 5 to 10 mph with their suggested ~0.8 “g” not activating ABS.
  • Drove for a minute (~1 mile) to let that layer of pad material bond with the rotor.
  • REPEATED 10 TIMES.
  • Then continued to drive 5+ miles without applying the brakes to allow rotors to fully cool.
If you want the full details of bedding (which I have used with other street driven Vettes) and other info this is a PDF I made that outlines and gives info from other sources re bedding: http://netwelding.com/E-Ray_PDI.pdf
