SavageGeese Reviews E-Ray!
Received 1,596 Likes
Unmodified C8 of the Year 2021 Finalist
Not the biggest fan of his videos, but he has some good canyon carving moments. Doesn't hold back on these roads either.
I know this isn't track driving but this is a GT car.
He drives some pretty exotic stuff and he says the 4000lbs doesn't translate during at limit canyon driving
https://youtu.be/8bFTn5iy8fI?si=Day_MbaCuDmPufgY
I also liked, in the savagegeese video, what they say about the ERay being better than the NSX (around 24 minutes in).
The following 3 users liked this post by Bob MacLean:
The following 2 users liked this post by fatsport:
RiptideHTC (10-14-2023),
Torque Obsessed (11-20-2023)
The following 6 users liked this post by combatninja:
CDNZR (10-15-2023),
PRE-Z06 (10-14-2023),
Schuee (10-17-2023),
Torque Obsessed (11-20-2023),
and 1 others liked this post.
I'm a current NSX owner and ex-C8 owner (sold my 23 70th Anniversary earlier this year which was my 3rd C8 over the years) and I'm keen to experience the difference between the NSX and the E-Ray. As someone noted above, I'm in the camp of coming from NSX's and GT3s and had ZERO interest in Corvettes until the C8. Currently I'm sitting at the #1 spot at my dealership to order the E-Ray and although these reviews state its a heavy car I can tell you the NSX is as well and I think its the best car I've ever owned. It too being a Hybrid with regenerative braking and CCB's is way faster than most would believe. I'll daily the E-Ray and keep the NSX up on the lift.
Here's my 17:
Here's my 17:
The following 7 users liked this post by CamsC8:
/Bear/ (10-14-2023),
70lt102z06 (10-14-2023),
91Vette (10-15-2023),
cwaddell (10-16-2023),
FH212 (11-20-2023),
and 2 others liked this post.
The following 3 users liked this post by FranknStein:
thats because you're one of those haters. C7 is an awesome platform. Since 2014. If you didn't catch on until 2019 then where were you? Chasing Ferrari? Porsche?
The following 3 users liked this post by kevinprimetime:
Received 9,090 Likes
Almost 2 million Corvettes have been sold since initial production. I guess no one was interested in them
The following 5 users liked this post by JABCAT:
Bwright (10-22-2023),
kevinprimetime (10-15-2023),
marc4427 (10-22-2023),
PRE-Z06 (10-15-2023),
i was watching The SmokingTiresPodcast channel on YouTube today where Matt Farrah talked about his review of the ERay. Without getting too specific he hinted that there could be issues with modifying that would need to be worked out with adjusting the programming of the electric motor working with the v8. Sounded like he got the info from a GM engineer. 49 minutes in…
Strait line performance with a PI LT2 would be epic assuming there isn't an issue with over powering the electric motor? Since the EM decoupled at 150mph, does it base on speed only criteria?
Keep in mind as the battery gets depleted quickly, having the extra hp will keep the party going during long duration WOT?
We will get that answer eventually.
Just my novice observation.
cwaddell (10-19-2023)
They mention the electric battery is recharged only through braking. So if depleted say on a WOT run up an entrance ramp and straight away then coasted down to acceptable speed, will the battery remain depleted if the car maintains a set speed (e.g., cruise control)?
#33
Plus there's a charge + mode button by your right thigh next to the auto start stop bs button. So dumb.
But a video on how the charge plus operation shows that the battery gets full very quickly even while accelerating.
JABCAT (10-15-2023)
#34
Lefty32 (10-15-2023)
#36
If these 2 drivetrains are independing of each other, there wouldn't be a hinder to either one if one was altered for higher performance? Sure you wouldn't have the perfectly dial-in oem driviabilty ie. on track use during turn/exit, so only draw back will be that the driver will need to adjust accordingly as one do presently.
The following 2 users liked this post by K-TownMike:
cwaddell (10-19-2023),
#37
Based on the comments about the complexity of integrating the powertrain for seamless feel, I suspect it may prove difficult.
The following 3 users liked this post by RapidC84B:
#39
Interesting perspectives. The wide body is pretty slick and the extra 160 hp 125 tq ready to fill in while the torquey 495 hp lt2
runs to the redline with each lightning shift of the dct.
awd makes it grab at all four corners to catapult forward ..
zero to 60, quarter mile, 30 to. 50, 40 to 60, 60 to 130 outpaces even the mighty 670 hp LT6.
that’s quite an accomplishment beyond the addition of awd at launch.
rides nice like a stingray z51.
#40
