C8 Forced Induction/Nitrous C8 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
P0121 Code
Old Mar 9, 2023 | 06:05 AM
Brentster63's Avatar
Brentster63
Cruising
Default P0121 Code
Hello all. I have a modified 2020 C8. Twin Turbos. I have been dealing with the code P0121. This happens when I jump on it. Regardless if it is from a standing position, or rolling. If driving normal, no issues at all, but this car is not designed for normal driving. I know when the car throws this code. When I slow down to normal speed, and drive normally, the car starts this hesitation thing. Very sporadic in natural if you will. Then I know. First thing, I plug into the OBDII with my new Launch X431 Pro 3S scan platform, scan for any codes first to make sure this is the code, 100% of the time it is, Then, I reset the code. Give it a minute. Start driving. Runs like a champ. Until I repeat as described above. I cannot get any where with the shop that did all my work. I have 20,000 miles on the car. I really need some help. Are there any suggestions or recommendations? Thank you.
Old Mar 9, 2023 | 07:27 AM
449er's Avatar
449er
CF Community Team
Welcome to the forum! You have come to the right place to ask all questions Corvette related....what is the P0121 related to?
Old Mar 9, 2023 | 08:29 AM
Sunwarrior's Avatar
Sunwarrior
Throttle position sensor/ switch
https://www.obd-codes.com/p0121
not a c8 but may help:
Old Mar 9, 2023 | 12:01 PM
Brentster63
Cruising
Default P0121
Awesome. Thank you. I will read, and watch to see if I can get somewhere with it!
Old Mar 9, 2023 | 12:10 PM
Andybump's Avatar
Andybump
From the service manual, here is the condition that causes this code to be set, and also what the car does when the DTC is set. I also included some statement related to diagnostic aids.
Old Mar 9, 2023 | 01:36 PM
RKCRLR's Avatar
RKCRLR
You may want to post in the C8 tech section or the forced induction section.
Old Mar 10, 2023 | 05:47 AM
Brentster63
Cruising
Thank you all for the help. I will keep you posted
Old Mar 13, 2023 | 05:38 PM
drich's Avatar
drich
3rd Gear
Who did the TT setup for you/what kit is it? I have a Cicio kit and have the same exact issue as you. I just clear the code when I hit a read light, and turn the car off then back on again to get the hesitation issue to go away.
Old Mar 13, 2023 | 07:03 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
I agree.
To the OP:
Since you have responses in this thread and none in the one you started over there, I’m moving this there there and deleting the thread you posted over there.
Old Mar 14, 2023 | 04:55 AM
Brentster63
Cruising
My guy came to the house and downloaded the tuning to send back to Peitz. I am hoping it is just a retune fix. I will keep you posted. Peitz supplied the module and tuning. I can allows clear the code, and wait for the car to reset, then works great. If i drive like my grandmother, i have no issues. As soon as I get on it, it will throw the code, and the car starts running like crap. Rinse and repeat!!
Old Jun 17, 2023 | 12:25 AM
Kayvon D's Avatar
Kayvon D
So what ended up happening brotha? Did you get it fixed!?
To P0121 Code
