A good read on the electrical delay
Autoblog knows no more than any of us. The whole article is speculation and guessing.
Hybrid collaboration with Cadillac. Dynamic and sustainable 48V buss. ...this is actually fun to speculate.
Not only this, don't forget they are also dependent upon suppliers and things who may also mess up or make changes. It's not impossible for Delphi to come back and say "hey, when we tested all the cool new features you put into the Corvette, we realized it ran to slowly, so we upped the components and need more power". And then GM redoes calculations, realizes that it is getting close to max, but should still work. And then during testing they realize, everything works great even with the new loads, except if you use both power windows at the same time, while sitting at a stop light when auto-stop has kicked in -- and they forgot to re-plan for that.
confidentially as an engineer...
Still find it almost impossible to believe that in this day and age of super computer simulations and Proto type testing and years of real world Field testing and data gathered from competitors cars that such a delay is possible. Somebody made some fundamental error‘s in assumptions and requirements early on and it was never discovered until a few months before they are about to go into production?
the engineers can make it so" and so 'they' throw hand-grenades over the wall, 'knowing' that the engineers will catch them and put the pins back in....until we can't!
Minivan day of pre-production unveiling (not pilot production yet) Chief Engineer; " We are 256 lbs over the weight target! Either we have to uprate the entire suspension and re crash-test the vehicle or EVERY department has to put on my desk by end of week every weight reduction they can achieve"....you can imagine the chinese fire drill.
I feel for those guys! X-mas in front of a Flat panel display!
Unkahal
Michael A (12-22-2018)
Maybe they are kicking the ball down the road to buy time. With the major overhaul of GM and the new focus on a narrower group of vehicles, we must expect that GM reviewed every vehicle's strategy, so, the current corvette strategy has been reviewed. Who knows what the outcome of that review was? Leak an electrical issue and you have cover until you are able to unveil the truth. We'll know in 6 months, or we won't.... Either way, it's all speculation.
Possible June 2019 press releases form GM:
"Mid-Engine Corvette program shut down due to electrical issue"
OR
"Mid-Engine Corvette debuts to Global praise" (I'd prefer this one)
OR
To me it's kind of head scratching. It's a pretty straight forward problem. The only differences I can tell are the headlights and PS rack being further away from the power source. I know it's DC but you shouldn't be seeing that much of a power drop with the distances involved.
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
Is there anyone here who thinks this was the first problem found in the development of this car? That's why they call it "development" instead of "final product". So the ME becomes a 2021 instead of 2020, so what. Better to find the problems now and fix them than rush ahead and release a headache. Corvette owners are picky and very critical of minor issues.
I not surprised at this delay. Also, I don't think it will be the last.
Yes, they are going further and powering more systems with the 48volt side but its a matter of degree, its not new.
It may sound unbelievable but lets not forget the past:
http://articles.latimes.com/1999/oct/01/news/mn-17288
Those who forget history are doomed to repeat it....
63 delayed
68 delayed
83 delayed
etc rinse and repeat!
63 delayed
68 delayed
83 delayed
Those minds are long gone from this good earth but were obviously superior proven by the results accomplished with the known technologies of their time.
#33
#35
It doesn't need to be perfect but at least safe and functional.A recall to fix a minor issue isn't bad but a harness replacement isn't a minor recall.
#37
Good read for sure
#38
Volvo will not be the first to use a 2 tier voltage system. They are not new. I cannot tell you who was first but ALL diesels that run HUEI injection systems run a high voltage section of the electrical system. Ford started using a 24 volt system on the 7.3 diesel in 1996 (Designed by Ford and used by IH, Ford and Cat) and has continued the system since. 2003 they went up to 48 volts. Not sure what voltage the current models use but I think its 80 volts.
and the military has used 24v's for 30-50 years
#39
Smaller conductors can be used for a given load with the higher voltage. That would save a few pounds except for all the added devices.
#40
