More evidence of C8 scoop shape... a 'duh' moment...
#61
No, I'm further proving they are not the front. They are the back. But I'm asking people to recognize the square shape that I see cutout from the fender, and I'm asking what it is.
#62
Thanks for the clarification.
If you look closely at my comparison above. I reversed the image to help amplify the colors.
You cannot see the support Armature through the fender at any point where the scoop opening should be and I do not see any indication of an opening at that particular point.
As I said earlier, the scoop opening may be CNC cut out in a secondary operation or that the scoop opening is just not visible in those particular images because we are not seeing the entire fender
bbbvettes.com (06-14-2019)
#64
I dont think a hatch hatch in that spot would be easily accessible as an electric port. Usually there are closer to the front ? And higher so you don’t have to squat.
Aslo in that location it would likely interfere with the scoop duct IMO.
Anything is possible since GM refuses to throw us a bone ! ; )
#65
The following 2 users liked this post by RapidC84B:
bbbvettes.com (06-15-2019),
firstvettesoon (06-15-2019)
