Hot cabin
Popular Reply
10-01-2019, 08:59 AM
Received 11,772 Likes
Not unless you drive really fast in reverse.
scorchin' hot
The following 7 users liked this post by Phil1098:
Birdy46 (10-01-2019),
kratedisease (10-02-2019),
mjbernatz (10-01-2019),
sTz (07-07-2023),
vampire81 (10-02-2019),
and 2 others liked this post.
No... if you watch any of the GM engineering presentations they specifically address this. The cabin is cooler as there is no hot exhaust running in the center tunnel.
Received 4,386 Likes
The engine is no closer to the cabin than before. In both cases it is separated by a thin firewall and a small air gap. As others have stated, the hottest part of the engine(exhaust) is now much further away.
The following 2 users liked this post by Racer X:
bdsvavars (10-02-2019),
bigblock427 (08-10-2023)
Many years ago I put a small block into a Fiero. The cabin temp was fine. The C8 will have no problem.
Received 1,817 Likes
You too? Fun cars!
The following 2 users liked this post by Warp Factor:
judge71 (10-02-2019),
Rufus Macblorf (08-10-2023)
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Banned Scam/Spammer
Are you serious? Where do these posts come from?
NCM Lifetime Member
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,492 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
The short answer is "no". The cabin will be no hotter than a FE car. It actually may be cooler as no exhaust under the floor. My F430 was never hot inside due to engine temps.
I mostly ran Hoosiers on the back of mine, and it would stay hooked at full throttle in second gear. You're right, regular street tires didn't do so well....
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
http://www.v8archie.us/
All I can say is my 2022 will get so cold you will be asking to turn it up
