Dyno results
Rock0720 (10-21-2019)
#123
If road and track did their nonsense negative good but not great...motor trend just did its BS dyno test to balance the PR nightmare from R & T...
click click click...read all about it from both auto magazines seems more like whats going on..
disappointing state of affairs when journalistic integrity is out the window on both sides.
nobody is getting560 hp out of a naturally aspirated motor...with out a turbo to dial up and down...its a dyno twist of the dial...or a dramatic change in correction factor....
id love this hp rating to be real but its click bait ..
The expert chimes in ~~ LOL
Check this motor from chevy -- ZZ 572/720R Deluxe
#124
Mustang Dynos use an Eddy Current Brake to replicate the ACTUAL WEIGHT and coefficient of drag whatever car YOU TELL IT is on the Dyno. It also asks for road hp at 55 or 60mph. I forget.
Tune time performance has had an awd mustang dyno for about 14yrs. I've operated it. Installed it. Relocated it etc... it's great for driveability problems as well. Nothing like the old school static roller dynojets.. the better dynojets use a brake now as well but they are way more money (like an awd mustang dyno).
Maniacs screwed up the inputs and viola. 60000hp and tq... idiots.
it's not "reading lower"... it's reading more ACCURATELY
The following 2 users liked this post by 23/C8Z:
RapidC84B (10-21-2019),
Satanspawn (10-22-2019)
#127
#128
Your post is click bait because its so ignorant....
#129
Somebody needs to be impeached over this.
94Lt1Vette (10-22-2019)
#130
Not so much fake news as much as click bait and bad reporting. The numbers are wonky and that should have been examined more thoroughly, whether it's a screwy dyno or GM screwing with the public with a ringer C8.
#131
Former Vendor
It actually sounds like the dyno was stuck in the awd coefficient mode when the 2wd mode was selected there for accounting for the 3 or 4 sets of front rollers that obviously weren't spinning... Im 95% sure that's what happened ( that and the 19500 miles I have put on my mustang dyno) I would bet our c8 will make about 410 to 415 wheel ... I understand it's not click bait ...
The following 6 users liked this post by TuneTimePerformance:
23/C8Z (10-21-2019),
ArmchairArchitect (10-22-2019),
NICK YOSKIN (10-21-2019),
range96 (10-21-2019),
and 1 others liked this post.
#132
Banned Scam/Spammer
FringbirdAloha (10-21-2019)
#137
23/C8Z (10-21-2019)
#138
Received 3,871 Likes
"Ask Tadge" Producer
Of course it's what they should do. It's not what they're going to do, though. They even told us what they're going to do: put another C8 on the same dyno in the coming months. I suspect that by then, the dyno operator will have figured out his error and the resulting numbers will be quite a bit lower. Just imagine the resulting article? "Proof that GM gave us a pre-production ringer!"
The following 2 users liked this post by jvp:
#139
5.5 liters is the C8.R race car. Limited by the rules to 5.5 without turbos, smaller (4.4?) with turbos.
#140
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,106 Likes
Oh no, now you've gone and done it. If they catch wind of this they will try to tie it to the WH.
I suppose someone didn't really know how to set up the Mustang dyno or read the numbers. When reading numbers more accurately than the dynojet I suppose it means, more accurate = lower values.
