Opening the door fully can chip your paint!
#61
E-Ray, 3LZ, ZER, LIFT
Received 9,746 Likes
Sure sounds like a screw supplier issue! If that is normal length variability- a design change is needed.
#62
Stop apologizing for GM. They made a great car, but mistakes happen. Better to point it out and get it 'on the list'. Also, QC needs to be trained better - attention to detail is important in this segment.
ArmchairArchitect (03-25-2020)
#63
Here is my door. Very close, maybe like a Credit Card. Don'
t know if the Dealer is going to be able to do anything about this, especially right now with many dealerships either closing or in chaos.
#64
Definitely need GM to become acutely aware of this situation so they can take ample steps to insure it doesn't happen anymore. I'm sure they will, it's a simple fix. easy. The harder part is the repair to damage..It's a shame it happened. In the big picture it's not a huge deal, but now you have the dilemma of paint match/blending.or trying some type of chip repair or maybe a"confined spray" if there is such a term.
I'm a do-it-yourself type but matching paint color is not that easy. What I do see in that close up is that the chip stays within a small body line."If it were me",I think my first attempt would be to TRY to keep all work inboard of that body line. A little filler, light sand(keeping as small as possible)and touch up spray keeping it too, as small as possible, and using the body line as a break point,not past it. This will likely leave a small paint ridge when you unmask,BUT it is on a line and you would still have all original paint on the overall large surface of the door and fender,and only inside that body line for a couple inches would be the repair spot. For me, I think I could live with a slight 1 inch paint lip in THAT spot,rather than a full door/fender blend. Or even a whole new door like OP was talking because you still may have paint variance. Car looks white to me or light grey. White is tough to match I hear
Than again I might just be crazy?
#65
plant was aware of this before the first post. issue has been addressed already. hope that helps. i'm sure Jeremy can confirm through his pal as well.
#66
#67
According to a Corvette team member the screw was too long obviously and it was caught and swapped during production early. Unfortunately some made it through.
Why they didn't contact the dealers that those cars went to? I will never understand. Maybe some were lucky enough to NOT open the door all the way yet. Is what it is.
#68
Exactly. I had a tater tot in my french fries one time.
The following 2 users liked this post by ext:
Corvettejimmy75 (03-24-2020),
Secret237 (03-24-2020)
ojm (03-31-2020)
#70
4th Gear
My C8 serial number is 870....just check both doors. I'm all clear, although the clearance is small like Kong's.
#71
Just had a break in the rain so I could back out and look at the right side. About a 1/4 inch gap. Same length of screw sticking out of the spring nut. Same door gaps..Might just be my eyes but the left side spring nut looks to be 3 threads deep and right side 2 threads. Or whatever that attaches to inside the inner fender is closer on the left. Either way is to close.
#72
The reason is simple because its cheap and corners are cut to make it affordable.
When C8 is compared to 911, people always omit what they want. They need to compare not only the lap times but the full package.
#74
Hmm, looks like it's behind the inner fender well. Probably have to remove it 1st. Much easier to just "Cut It Off!"
A Hacksaw Blade should do it. There are holders that allow you to use one end BUT wrapping a rag around one end works!
#75
Thanks for sharing so we all can look at ours before it gets too bad.
#76
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,919 Likes
This is what I was saying in the other thread in regards to explaining of why this car requires post delivery wing installation which itself requires removal of bumper and drilling of holes....
#77
looked at upper screw so my earlier post is incorrect. With door fully open you hardly see the screw in question. Drivers door has approximately 1/8” clearance and passenger side more like 3/16. Both side show screw end just protruding and nothing to the extent shown that caused damage..
JerryU (03-27-2020)
#78
Received 5,325 Likes
I'm sure when they get back to work, having experienced a 20% pay cut, they'll do a much better job.
#79
Getting to be a launch disaster quickly
The curses just keep coming for this car. Late to launch, strike, virus, and now further unhappy workers to build them. Was so excited about this car two years ago. Sold my 2019 GS for this car. Placed my order in July into workbench but had order in for 18 months prior w dealer in his first folder. Was two weeks from build and now who knows? Be safe all!
#80
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Could it be that we are talking about a screw used in both locations that is okay for the top position but too long for the bottom? A shorter screw for both locations would resolve the issue, and stocking correctly two different length screws isn’t efficient and easily grabbed from the wrong part bin at that station.
JerryU (03-27-2020)
