Sponsored by: Wheel Design
2021 VIN Decoder
Old Feb 4, 2021 | 09:18 PM
Zymurgy's Avatar
Zymurgy
Moderator
Default 2021 VIN Decoder
This is an example of a VIN # for a 2021 Corvette Coupe (3LT):
1G1YC2D45M5109199
There are 17 characters. Starting with first character on left the codes are:
01. "1"= Built in US
02. "G"= General Motors
03. "1"= Chevrolet
04. Denotes the car line: Corvette is a "Y" body.
05. Trim level:
.. A=1LT
.. B=2LT
.. C=3LT
.. 9=export (Non US, Non Canada)
06. Body style: "2" = Coupe, "3" = Convertible (HTC)
07. Restraint code: D – AJ7 Active Manual Belts, Airbags – Driver & Passenger and Seat Side
08. Engine: LT2 = "4"
09. Check Digit – 0 to 9 or X
10. Model year: M (2021)
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #100001 for each model yr.
000001 = captured test fleet cars
100001 = regular production
Old Mar 22, 2021 | 01:46 PM
Zymurgy's Avatar
Zymurgy
Moderator
The check digit can be 0-9 or 'X'.
An overview of the process for calculating a VIN's check digit is as follows:
  1. Remove all of the letters from the VIN by transliterating them with their numeric counterparts. Numerical counterparts can be found in the table below.
  2. Multiply this new number, the yield of the transliteration, with the assigned weight. Weights can be found in the table below.
  3. Sum the resulting products.
  4. Modulus the sum of the products by 11, to find the divisor.
  5. If the divisor is 10 replace it with X.
Transliterating the numbers
Transliteration consists of removing all of letters and substituting them with their appropriate numerical counterparts. These numerical alternatives can be found in the following chart. I, O and Q are not allowed, and can not exist in a valid VIN; for the purpose of this chart, they have been filled in with N/A (not applicable). Numerical digits use their own values.
Transliteration key: values for VIN Decoding
A: 1 B: 2 C: 3 D: 4 E: 5 F: 6 G: 7 H: 8 N/A J: 1 K: 2 L: 3 M: 4 N: 5 N/A P: 7 N/A R: 9
S: 2 T: 3 U: 4 V: 5 W: 6 X: 7 Y: 8 Z: 9
S is 2, and not 1. There is no left-alignment linearity.
Weights used in calculation
The following is the weight factor for each position in the VIN. The 9th position is that of the check digit. It has been substituted with a 0, which will cancel it out in the multiplication step.
Position 1 2 3 4 5 6 7 8. 9 10 11 12 13 14 15 16 17
Weight . 8 7 6 5 4 3 2 10 0. 9. 8. 7. 6. 5. 4. 3. 2
(ignore the "." above - they are to get the spacing correct)
Old Jun 26, 2021 | 01:18 PM
PatricksPC's Avatar
PatricksPC
Default Find your VIN from your Sequence number,
I made an Excel spreadsheet to calculate the check digit and display your VIN.
All you need to know is your sequence number and your options.
Download the attached Find Your VIN (don't forget to enable editing when asked)
Moderator - you may place this in a sticky
Patrick
https://www.corvetteforum.com/forums...n-decoder.html
https://vpic.nhtsa.dot.gov/decoder/C...Y72D43L5101153
VIN Decoder - CorvetteForum - Chevrolet Corvette Forum Discussion
File Type: xlsx
Old Jun 26, 2021 | 01:42 PM
RandelB's Avatar
RandelB
Default 10th Digit VIN Year Codes
Old Jun 26, 2021 | 02:32 PM
Green Streaker's Avatar
Green Streaker
Thanks PatricksPC. Now I have my complete VIN with the check digit.
Old Jun 27, 2021 | 06:52 AM
/Bear/'s Avatar
/Bear/
Veteran: Marine Corps
2025 C8 Z06/7/E-Ray of the Year Winner - Unmodified
2021 C8 of the Year Finalist - Unmodified
Once my order went to Status Code 3400 and I was able to get the last 8 digits of my VIN from MacMulkin's website, I used the information on this page to calculate the entire VIN of my C8 -- including the Check Digit -- and it worked perfectly, as confirmed later by multiple sources.
Thanks for providing this useful information!
Old Jun 27, 2021 | 08:40 AM
C8J's Avatar
C8J
There are a number of internet VIN decoders. Some are "better" than others. I'll leave generating check digits to others, but very interesting @Zymurgy for providing the how it is generated. Never knew the algorithm. All that said, once you actually receive your entire VIN, it's much simpler to use one of the many VIN decoders to break down the meaning of each digit.
Old Jun 28, 2021 | 02:51 AM
alexanderadamali's Avatar
alexanderadamali
2nd Gear
Once my order went to status Code 3400 and i used to be able to get the remaining 8 digits of my VIN from MacMulkin's website, I used the records in this page to calculate the complete VIN of my C8 -- which include the test Digit -- and it worked flawlessly, as confirmed later by way of multiple resources.
Thanks for providing this beneficial information!
To 2021 VIN Decoder
