Sponsored by: Wheel Design
Xm antenna
Old Sep 18, 2023 | 08:28 PM
M&N's Avatar
M&N
Default Xm antenna
I tried google but where is the xm antenna located on a c8?
Popular Reply
Sep 18, 2023, 10:59 PM
Andybump's Avatar
Andybump
The antenna that provides the XM signal is called the High Frequency Antenna - Left Front. It is located under/behind the left front fender. See the attached schematic that indicates the antenna that supplies the XM signal, and then two clips showing where that antenna is located.
Old Sep 18, 2023 | 08:53 PM
sshallen's Avatar
sshallen
I found this in a 2020 launch document.
I don't think it is correct. I'll bet it's in the windshield header, but I am admittedly guessing.
Old Sep 18, 2023 | 08:55 PM
Red Mist Rulz's Avatar
Red Mist Rulz
On the C7, it was behind (or maybe in front is a better description) the rear fascia, behind the trunk. Don't know if it's the same on the C8.
Agree that the wordingin post 2 is probably an error, copied from some other vehicle that has one of the shark fin antennas on the roof.
Old Sep 18, 2023 | 10:59 PM
Andybump's Avatar
Andybump
Old Sep 19, 2023 | 01:03 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
What did we ever do before @Andybump and his manuals appeared to supply us with factual, documented information? Thanks Andy!
Old Mar 4, 2024 | 01:36 AM
22c8z51's Avatar
22c8z51
How to access this antenna? I want to wrap it in foil for science. Would this disable GPS, cellular, and block broadcast of telematics to GM?
Old Mar 4, 2024 | 06:42 AM
Thanks for the info and diagrams on where the antenna is located.
Old Sep 3, 2024 | 08:04 PM
pistolpete817's Avatar
pistolpete817
Where is the FM antenna located?
Old Sep 5, 2024 | 11:50 AM
Walter Raulerson's Avatar
Walter Raulerson
One used to be inside the outside mirror
Old Sep 5, 2024 | 12:32 PM
C5racecar's Avatar
C5racecar
Man these cars are complicated. It's not like the old days when twin antennas gave you great AM reception.
To Xm antenna
