Another Trunk Heatshield Thread
The test was a 30 minute spirited run in Z mode through the local hills followed by a 45 minute heat soak in the garage. Both runs were about 2 hours apart and in both cases the fans were running after shutdown (Z51). Temperature was taken with a Fluke IR meter in the center of the trunk where the exhaust sits (Borla ATAK). Net result was a 20F decrease. Product is 1/8” thick, very workable and applied with 3M tack spray on both the back of the carpet and the Heatshield Product matting.
https://www.corvetteforum.com/forums...-solution.html
But it is amazing how some are willing to improve the area. Good effort! Maybe GM will improve on you guys findings.
Very good SoCal-C8 and others. You guys do make a good thing even better.
