New TREMEC 6-Speed Manual Transaxle Redefines Custom Performance
.........................nonZ51.. Z51
First gear............... 2.91 .. 2.91
Second gear.............. 1.76 .. 1.76
Third gear............... 1.22 .. 1.22
Fourth gear.............. 0.88 .. 0.88
Fifth gear............... 0.65 .. 0.65
Sixth gear............... 0.51 .. 0.51
Seventh gear............. 0.40 .. 0.40
Eighth gear.............. 0.33 .. 0.33
Transfer ratio........... 4.89 .. 5.17
Overall ratios:
First gear...............14.23 ..15.04
Second gear.............. 8.61 .. 9.10
Third gear............... 5.97 .. 6.31
Fourth gear.............. 4.30 .. 4.55
Fifth gear............... 3.18 .. 3.36
Sixth gear............... 2.49 .. 2.64
Seventh gear............. 1.96 .. 2.07
Eighth gear.............. 1.61 .. 1.71
After 5th gear in a C8 the other gears, especially 7th and 8th are there mainly for GM to achieve higher mpg in the EPA Required mpg test. For both City and Highway required test cycles if you look at the acceleration required, the C8 probably only needs about 75 hp. Very light throttle. Heck that test is defined so ~100 hp cars can met the acceleration rate requirements.
I don't use an Interstate so even my excursions to triple digits in our rural area, are when accelerating fast and quickly backing off. So 5th is all that is needed and all in Z-Mode it automatically uses. JUST because GM provides the higher OD gears doesn't mean you have to use them!
Granted max speed in 5th is ~120 mpg (Z51 gearing.) 6th max speed ~160 rpm. So a 0 to 160 would need a shift to 6th. If for whatever reason your hung up on 60 to 130, sure a specific gear ratio would be better. But could say the same for 60 to 140! Now if you are roll racing for money (foolish IMO) you could achieve close to 130 mph by swapping the Z51 intermediate gear set to the Base 4.88 versus 5.17 combined ratio. That would get to to 127 mph! Assuming you don't want a Tune to increase the max rpm from 6600 than a simple solution, just use a slightly larger diameter rear tire, somewhat wider or 35 versus 30 aspect ratio!
In fact if you are racing a friend with a Base C8 versus your Z51 they will best you 60 to 130! Especially if they installed slightly larger diameter tires!
SIDEBAR
As far as gas milage driving in Z-Mode versus letting the car use all gear in say MY Mode (I only use those two Dive Modes hardly very use the drive mode **** all done with the steering wheel Z-Mode button. I toggle between the two) I conducted a 1 Tankful test. Used Z-Mode ONLY for a tank full of gas versus driving about the same in my trips, which are ~60 mile round trips to and from Town only using MY Mode.
I tried my best to drive about the same in both. Accelerated from stop signs and achieved about the same high speeds where there are only farm fields both sides of the mostly 2 lane rural roads. In those two tank fills the mpg difference was only slightly more than 1 mpg in MY Mode! MY Mode used all 8 gears and V4. In Z-Mode seldom past 5th and never V4.
Overall ratios:
Nice job!
.........................nonZ51 DCT... Z51DCT….. New Manual 6
First gear..................14.23 ……..15.04……....12.536
Second gear.............. 8.61 …….. 9.10………….8.594
Third gear................. 5.97 ……… 6.31………….5.960
Fourth gear............... 4.30 …….. 4.55…………..4.289
Fifth gear.................. 3.18 …….. 3.36…………..3.191
Sixth gear................. 2.49 ……… 2.64………….2.484
Seventh gear............ 1.96 ……… 2.07
Eighth gear............... 1.61 …….. 1.71
ey GM, are you trolling this forum, check out this video, and if you do bring this car to the market, sign me up!
I say the same about a gear set. they have the full design and drawings, making a gear change set for the DCT for aftermarket world would not take a lot.
a C8 with a DCT set up for more of the use and end around a normal 6-7 speed OD... would be FAST with moderat power.
A manual transaxle in 2025 feels almost rebellious in a good way 😂
Not sure if it's hinting at a manual Corvette revival though… GM seems pretty married to DCT for the C8 platform. But it could open some crazy possibilities for custom builds or restomod C7/C6 projects.
A manual mid-engine Vette would be wild though. If GM ever gives us that in a Grand Sport, the internet will explode.
Some people care enough. Other people would rather sell the C8 and just spend the money on something with more badge prestige.
