C8 General Discussion The place to discuss the next generation of Corvette.
Sponsored by: Wheel Design
Software Update Question
Old Mar 14, 2026 | 12:34 PM
Scruff Vette's Avatar
Scruff Vette
Default Software Update Question
Received this update on my '25 Stingray: 85759705.mnf SIHM23B-00383.01 a few days ago. Recently had the battery replaced under warranty. No issues with the car, just curious what it was for.
Old Mar 15, 2026 | 11:18 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
We want to help provide support in an effort to address your questions regarding the software update you received. To help us do so, please send us an email with these details to socialmedia@gm.com. With that, be sure you include "Scruff Vette Corvette Forum" in the subject line of your outreach so we can get started. Our team will keep our eyes peeled for your message.
Old Mar 15, 2026 | 12:37 PM
papillion's Avatar
papillion
Default Still There
The update is downloaded to your car without you knowing it has been done. Done in the background using the car's native LTE. Only then do you get the notice that you can install it. It will remain active for 30 ignition cycles (on/off), then it will be deleted from the car's memory. The descriptions are usually vague including targeting issues described using 'various' and 'misc'. Depending on how long it has been, the update might still be installable.
From the info screen: Home>Settings>System>Vehicle Software>Updates
This will display both installed and pending updates. Caveat, this is for my 2022. I'd guess 2025 is similar certainly enough so to get headed to the general vicinity.
Old Mar 15, 2026 | 12:44 PM
Andybump's Avatar
Andybump
At least on 2020-2023 and maybe beyond, there is a setting in the menu to allow or dis-allow downloading of the update in the background. If you disable that, then you will also get a notice that an update is ready for downloading (not be confused with installing). I have mine set to allow it - and it will download via the built in 4G and/or your home internet enabled WiFi if you have allowed the car to connect to that when it is "home". I have.
Old Mar 15, 2026 | 06:56 PM
Scruff Vette
Using the System>Vehicle Software>Updates on my '25, it showed up under "Previous Updates" so I am thinking it's installed. I'm just curious as to what the update was for.
Old Mar 16, 2026 | 09:02 AM
Chupacabraz's Avatar
Chupacabraz
I hope it addresses the radio cutting out repeatedly for the first 5-10 minutes of a drive! Haven't seen any update messages on my 2025 so far though.
Old Mar 16, 2026 | 09:09 AM
Scruff Vette
Wow, I never had that problem with the radio. Still have no answer what it addresses. Chevrolet Customer Care says they don't have access to the info.
Old Mar 16, 2026 | 01:10 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
does the vehicle need to be hooked up to your homes wifi ?
Old Mar 16, 2026 | 01:22 PM
AlexMonroe75's Avatar
AlexMonroe75
No response from OpenClaw.
Old Mar 16, 2026 | 03:11 PM
papillion's Avatar
papillion
Default Easy does it......
The update will download using the car's LTE. It does not require Wi Fi. It just happens poof it's there. Car says I've got it onboard and ready to install. Then you choose to install now, later, or not at all.
Old Mar 16, 2026 | 03:31 PM
Eliredandblack's Avatar
Eliredandblack
Great Post. My 2023 Z51 is a certified Garage Queen (others cars keep her blocked in). I took her for a Cruz and noticed when I open the door and closed it … the Horn Sounded. When I returned home and sitting in the driveway, I went to the vehicle setup screen and changed the setting. Not sure how this setting was changed, my thinking is it was from a software update?
Old Mar 16, 2026 | 04:44 PM
DA KAR's Avatar
DA KAR
@papillion thanks
To Software Update Question
