C8 General Discussion The place to discuss the next generation of Corvette.
Sponsored by: Wheel Design
Usb
Old Mar 27, 2026 | 11:08 AM
jmoody66's Avatar
jmoody66
Default Usb
I use my USB stick for music. Took the stick out and added some music and now the car doesn't recognize anything being plugged in so I attempted a reset of the head unit but it didn't react to me holding the button down.
suggestions?
Old Mar 27, 2026 | 02:39 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Others know more than I, so
* start the car, open the drivers door, shut off the car, wait 2 minutes, close the door( this is also a reset process )
* check the USB memory stick on a computer, insure files and directories can be opened and checked
* do a file system check by right clicking on the drive, select Properties, select Tools, Select Check
* You could delete songs, files, directories that were added if you remember what was added
* you might find other files that were added by error
* Last resort, reformat the USB stick and add songs again
If all this fails, you may have blown the USB port fuse!
Old Mar 27, 2026 | 03:02 PM
C5racecar's Avatar
C5racecar
Did you use the preferred method of converting songs to a Stingray play list? If you add songs, you need to add in the right format.
That is how I did it. I will try to attach the pdf..
To Usb
