C8 General Discussion The place to discuss the next generation of Corvette.
Sponsored by: Wheel Design
3M 3614 two-sided tape removal
Old Today | 10:29 AM
cmonkey713's Avatar
cmonkey713
Default 3M 3614 two-sided tape removal
Working on a C8 that has had numerous aftermarket engine bay covers installed with 3M 3614 double sided tape. The tape leaves a considerable amount of residue that needs to come off. We have tried Goof Off, WD-40 Alcohol, and other usual adhesive removers with limited success.. Is there an industrial remover that is safe for the bare composite in the engine bay area that we can try? Thanks!
Old Today | 10:40 AM
3M makes an adhesive remover that has reportedly worked well without any damage. Might want to check with a body shop or automotive paint store.
Old Today | 10:53 AM
frankbicknell's Avatar
frankbicknell
Curious as to why the removal. Did it not look good? Is it defective? Any before pics? May save the rest of us the same aggravation.
Old Today | 11:54 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
3M Adhesive Remover. It comes in spray or liquid. My bodyman turned me onto it years ago. It evaporates quickly so it doesn't soften finishes, etc.
https://www.google.com/search?q=3m+a...obile&ie=UTF-8
Old Today | 11:55 AM
cmonkey713's Avatar
cmonkey713
The current owner did not like the theme and color combo the previous owner had installed. It was a poor DIY project and the covers needs to come off. Some of the pieces are broken and unusable.
Old Today | 12:28 PM
papillion's Avatar
papillion
Default another vote.....
Old Today | 12:50 PM
cmonkey713's Avatar
cmonkey713
After doing some homework, I called 3M customer service and the sent me to the automotive customer service. the 3M recommendation was Adhesive remove 49048 which is an industrial citrus-based remover. The 3M tech said 49048 is the most powerful remover they have and still safe for paint and other finished surfaces. Available from numerous sources for around $40 to $50 for an 18 oz spray can. I have a partial can of 3M 03618 that I will try first. Thanks to all. Hopefully this will assist other members in the future with this situation.
Old Today | 01:27 PM
lgodom's Avatar
lgodom
I've used 03618 and found it lacking on tape holding on an emblem. Goo Gone is citrus based and worked better for me. I'd try it before spending the $$ on the 49048.
Old Today | 09:33 PM
promethius's Avatar
promethius
Did you leave that Goo-Gone sit for a couple of minutes on the item. Never had it not work......but you have to give it time!
Old Today | 10:34 PM
23cpe3lt's Avatar
23cpe3lt
I use wheels
http://a.co/d/01mAddDt
Old Today | 11:25 PM
Ron71's Avatar
Ron71
I have used the 3M Adhesive Remover 08984. Works great on removing adhesive.
To 3M 3614 two-sided tape removal
