If they did their job right they tailored the suspension spring rates and MSRC settings to the job at hand. The base suspension is described as set for touring so I don't think you can say they used all Z51 (lighter car with lighter wheels and brakes) or E-Ray (heavier car with lighter brakes). There may be some shared parts but I'd expect some specific parts/settings or a mixture of parts.
The GS comes standard with MSRC though, so technically it has a touring setting no?
I’m less concerned about the spring rates and more about the anti roll bars and bushings.
If I was to guess:
Grand Sport Base = Z06 suspension package with minor MRSC tuning to run more compliant with the all-seasons, or the exact same as the Z52 sport/Z06 Base
Z52 Sport = Z06 base
Z52 Track = Z07
We also have to remember the Z06 is nearly the same weight, and with the Aero packages also being similar, aero loads will be the same as well. If this is a parts bin car, then parts bin spring rates, suspension bushings, anti roll bars, and MRSC tuning would make the most sense economically.
Yes, but spring rates and shock damping do different things. Shock damping can be used to mimic spring rate to a certain extent but in an optimized system the spring rates and damping are tuned for the specific use points. In cars with MSRC they may optimize the spring rates for touring and use damping tuning to firm up the suspension for track use or optimize the spring rates for track use and use damping tuning to soften up the ride for touring, or somewhere in between. They may be able to go to the parts bin for springs, sway bars, bushings, etc. or they may decide to have some specific components for the different GS suspensions. It is possible that all of the components are exactly the same as some other C8 suspension system but it is also possible that they will be different.
I assume even the base GS will have PTM because it has mag ride. Wouldn’t that PTM have a “track” setting even though GM advertises the base GS as a Touring Suspension? Wonder how the MSRC shocks will feel in the “track” setting of a Touring Suspension? What I ‘m getting at here is you should certainly be able to enjoy good track performance from the base GS compared to say the SR Z51, even considering the all season tires on the GS? Anyone care to guess?
I think the base GS will be like the E-Ray suspension which is designed for all seasons yet it still pulls 1G, the ZER package gets you the P4S tires though no changes as far as I’m aware on actual suspension changes. The sport Z52 package on the GS gets you not only the better tires and suspension, but better brakes though the cooling system is the same and I thought that is the reason the base Stingray isn’t track worthy more than anything compared to the Z51. The tires, brakes and suspension help make the Z51 more track worthy, but the cooling upgrade is necessary.
If I was to guess:
Z52 Track = Z07
Watched the video you posted from the bash, but didn’t see clarification on the suspension differences. Did you happen to ask or hear anything while there? Saw you can option the wing w/o track package on GS and all LS6’s get the upgraded auxiliary cooling package.
After you do $9k TOF and $9k CCBs you might as well just get the full track package unless you REALLY don't want the Cup tires.
I saw extended front splitter for $1k and wing $2k, Z52 sport package is $3500 are you not allowed to order them individually like that?
Yes, you can do those options individually, but to be clear (if you weren't already aware), the "extended" splitter, while similar, is not the same design as the one included in the CF Aero & Track packages, and the $2K wing is the "three-stanchion high wing", not the Z06-style wing from the CF Aero/Track packages. Also, both of those are composite material rather than carbon fiber.
The Z06 high wing package is $9k in carbon flash and requires the $9k ceramic brakea be ordered with it.
I think you can get the newer three stanchion wing in carbon flash for ~$2k. It is a dealer LPO. Installed at dealer, not the factory.
Thank y’all for clarifying, so the $2k wing on the GS is like the old Z51 high wing? Heard the Z51 low wing angle changed on the ‘27’s for more downforce.
If you look towards the end of the thread on "what spec are you targeting" in the GS forum I posted a few video links that would probably help if interested in 3 stanchion wing...
Its similar to the current Stingray high wing, but considerably larger and a little more aggressive design, IMO. I never really warmed up to the Stingray high wing, but I kinda like the three-stanchion. Here's a Rick Conti video that really shows it off, or you can go into the GM configurator for the 2026 Z06 and add it to a car and see what it looks like.
My apologies, I wasn't there and that video was one I found on youtube.
I thought I saw/heard in a video that the Z52 MSRC and suspension tuning was different than the base, but now I can't find it anymore. Perhaps I imagined that.
The wing that can be optioned separate from the Z52 Track, is the three stanchion high wing. To get the Z06 wing you're still required to get the track package and CCB's.
V09 auxiliary cooler now standard on all Ls6's, but only the Grand Sport gets the same thicker front cores as the Z06/ZR1. From what they mentioned it made it seem like there are no more center rads on the Z06/ZR1 anymore, just the GSx will have it for the electric motor.
There’s lot of different Corvette customers who use their cars in different ways, and within the new Grand Sport lineup, engineers created three options to accommodate.
Standard Touring Suspension: The base Corvette Grand Sport gets a chassis tuned for daily use and spirited driving alike. Magnetic Ride Control dampers come standard, as does Michelin Pilot Sport All Season 4+ tires and a new brake package to offer great performance while minimizing dust. “This offering is the ultimate GT, canyon-carving, road-tripping, all-out Corvette,” Holder says.
Z52 Sport Performance Package: This adds Michelin Pilot Sport 4S summer tires1, a stiffer suspension tune, and the J56 high-performance iron brake package from the Z06. “That car is meant for the enthusiast that plans to take their Grand Sport to the track,” Holder explains. “We want to offer something that’s within the tradition of the Grand Sport.”
Z52 Track Performance Package: For ultimate track performance, this package adds the J57 carbon-ceramic brake package optional on the Z06, Michelin Pilot Sport Cup 2R summer tires1, unique suspension tuning, and a carbon-fiber aero package. “This package is very mission-specific,” Holder says. “It's for the particular customer that's looking for super handling capability but wants the big-torque performance of the LS6.
