Will 6.2 OHV V8 be offered as third engine choice....or DOHC V8 not mentioned yet.
I personally do not believe the pushrod 6.2L will be offered in the ME, my reading of the forecast was 4.2L and 5.5 L both DOHC version for Y2 which we all assume is the ME, same forecast shows 6.2L Y1 which we all know is the terminology for the current Corvette.
I'm sure the auto mags would rake GM over the coals for using the old pushrod in a modern ME.
And the reality is GM doesn't HAVE to use it.
We know they can build a good DOHC engine (see the XLR's).
You simply cannot look at this car, particularly in person, and not salivate over it. Its like nothing else. The LaFerrari may be in the same league.
I know that this is off topic, but I just wanted to point out... and not that I'm a bigger fan of one or the other, but keep in mind that...
in 2013 this was the LaFerrari:
... and in 2013 this was the Ford GT:
Point being, the LaFerrari was released well before the current version Ford GT (which was released several years later). So with that said, the Ford GT may be (more like hopes to be) in the same league as the LaFerrari.
Hmm, Ford can get 647 hp from a 3.5 Liter V6!
Maybe Chevy should do them one better and build an engine following the Colombo V12 that he designed for Ferrari. First ones, 1.5 liter (90 cid) with 2 inch diameter pistons! A unique sound! Can hear that 8000 rpm, quad turbo, DOHC, 4 valves per cylinder, (intake ~1 1/4 inch diameter and exhaust ~7/8 inches!)
Wouldn't you love to hear that screaming behind you when you shift out of first!
I agree with you “sinor”, and came to that same conclusion a few weeks ago based on the extreme time and consequent costs of configuring three different engines for just the ME platform. I am thinking of not just the different engines, but also the complete “arrangement” of all other components within the engine compartment, coupled with the extensive costs and calibration time for all other drivetrain and suspension components necessary for three different motors within the ME platform.
Each motor will not only weigh a different amount, but especially in case of the 6.2L, have a major difference in center of gravity compared to the two other motors (the 4.2L & the 5.5L). GM is still fine tuning the the MSRC shocks software now four years after the C7 came out. To develop different cooling, exhaust, suspension, motor/transmission integration, stability control, and many other systems for three ME motors just does not seem timewise-nor-costwise possible between now and the estimated late spring/early summer, 2019 production of for-sale ME’s, i.e., IMO, there will be no 6.2L available in the ME.
I have never understood the displacement debate. Displacement only matters if you are trying to fit into some racing rulebook, or to appease some taxing authority that taxes cubic inches.
What really matters on the street is exterior dimensions of the engine and its weight. OHC motors were developed long before cam in block (pushrod) motors, which are simpler and cheaper to build, have a lower center of gravity and generally smaller external dimensions, and in most street applications, have more HP per pound, at least in naturally aspirated form.
DOHC motors are fine, but nevermind--we are going electric anyway, right?
Corvette Forum Member ZERV leaked this photo on the “Code Name ZERV” C8 thread yesterday. And I thought that Ford GT engine is an In-line 6 that makes about 650 horsepower. The it’s easy to make power, just hard to make it affordable and reliable. A 3.6 liter V6 with two decent size turbos, high boost, and a high redline can make 650hp, but the engine wouldn’t be nearly as reliable as a 4.8 liter V8 with smaller turbos, lower boost, and a lower redline.
Huh? So adding 33+% more parts makes it more reliable?
That really is an impressive number.
Maybe not as impressive as today's F1 engines of 1.6L V6s putting out 900+ horsepower, but still...
What would be really neat and save a lot of gas is the F1 KERS! 160 hp for ~10 seconds using braking energy recovery would be great for acceleration or just starting any time!
Starting is a big consumer of gasoline and 160 hp is more than needed for the typical start from a stop. Would also be great to have that extra 160 hp when accelerating in anger!
An electric motor/generator just attaches to the crack and when not driving the car generates the power for the small battery! Kind of a hybrid but very light as the battery only stores enough power for ~10 seconds. The weight in an F1 race car is reported to be ~35 kg (~75 pounds.)
That's where I'm at too, but I think it's really tough to get the big numbers and the EPA mileage numbers (even though real world mpg is great) out of a big displacement NA engine.
My dream ME Vette? All the new chassis tech but with the Z06/ track edition being outfitted as such: CF 18" wheels all around, a removable roof (and a foldable canvas one as a spare for road trips while retaining trunk storage of luggage), manual but heated seats. 7 speed manual trans, rwd, iron 2 piece brakes with factory cooling ducts and plugs, and a 7.5-8.5 liter OH 16 valve lightweight NA engine.
The ZR1 should be the rich older guy car with the 20"wheels, ceramic brakes, **** ton of FI power, auto trans, over the time amenities, etc... The Z06 should be a track ready street car built to be lightweight, reliable, and a driver's car for the racetrack.
This makes the most sense to me as well ..but seems to contradict the engine forcast.
IIRC, Porsche has licensed KERS from Williams(?) for use in streetcars.
I prefer the old KERS over the latest overly-complicated hybrid tech in F1.
When I and another person did some “back” investigating about the Forecast’s validity, before of course the recent leaks and we had a chance to learn something from GM staff, a person said that it was not totally accurate, though parts of it were on track. That was all this person would say, of course that person not sharing what part of the Forecast’s several predictions were not perfectly accurate.
I think we are just going to have to wait another 374 days to find that out.
Being an ME I liked the flywheel storage one used by some teams when KERS was introduced initially! All are using electric motors and batteries now! That is what Porsche had on the floor of a racing 911 type!
I recall a concern was that 60,000 rpm flywheel getting loose after a crash! Could mow down a lot of folks!
The different engines packages that have been suggested are interesting. Although, Im not sure I buy the big HP numbers that are being tossed out there. And thats mostly just going off the visual impression the cloaked car is giving. Its not low/wide and aggressive with big section tires. In fact it looks kind of whimpy. And with that engine back there its not like they're going to have room to slap on bigger rear section tires unless they widen out the fenders.
And I dont think using the Ford GT as a role model is the way to go. Sure it looks sweet but where's its track times? The thing sucks. For $400k the thing really sucks. They're not bragging much. The Porsche guys with their new GT2 on the other hand...
The early ME CAD leaks show what looks like an OHV V8, so I wouldn't count it out just yet.
GM already has separate MRC calibrations for every single model of the existing C7 (see the update software threads where the different variations are listed, and the Ask Tadge question where Jim Mero details how each calibration is model specific) so I think GM has already shown they will do integration work for variations within a platform.
I think this motor could very well be a new design to share with trucks and SUV’s. I am kind of in the diesel pickup business and can tell you that a lot of people are stepping away from the diesels now due to a number of design issues and are looking for that kind of working power in a gas engine. And this would be a great way to do that.
