Tire mounting lug guide alignment tool
Hopefully, the new design for the C8 ends up where I can still use the primary large tube piece, and just need to buy what ever front wheel adaptors are required. Wishful thinking, I know.........
They look like jewelry in person, beautifully done.
Great product and as you say, look like the precision tools they are. I bought the longer 7 1/2 inch ones for my Grand Sport, 12 inch wide rear wheels, makes changing easy. Recommend buying 3 . I deal with my 420 Section Width Street Rod tires and wider wheels but fortunately don't have to take them off often!The Lug Guides come in two lengths, 5 and 7 1/2 inches. I have the shorter ones for the C8, which should be fine for the 11 inch rear wheels. In fact, just checked and the longer ones are sold out. Have to look for the different lengths when ordering as they are not on the same web page.
I can't remember who sold it, but I thought it was clever. There are usually several ways to "skin a cat."
Does the above tool used as a guide for each wheel, while mounting a wheel, then it is removed and moved to the next wheel, and so on?
Is this something that I want for my base, non-Z51 C7 to have the Discount Tire tire jockeys use when changing out tires on my C7?
Thanks for some instruction here.
Hmm, neither are permanent. Not sure where that word "permanent" used in a post meant.
The Reverse Logic Lug Guides are screwed onto the lugs and removed as you place lug nuts on after each is unscrewed. The other works off the center hub and you have to remove the center wheel cap to use and place the center wheel cap back when the lugs are installed.
Had my 2014 Z51 for 3 1/2 years and with the narrower rear wheels not as necessary but can help. I bought mine when I got my 12 inch wide Grad sport with it's 12 in wide rear wheel. Used on my fronts, which are the same tire/wheel as the V7 C7 rears. Does work but would not say it's "needed" unless you're changing wheels frequently.
IMO Discount Tire, etc folks won't take the extra time to use them, They are used to putting wheels on and do it all the time.
The difference is the tool I prefer screws onto the rear center hub on the back, and inserts into a provided adapter on the front hubs. Note different shape on each end of the tool. On the other hand, the alternative method multiple rods screw on to several of the lug studs.
When changing a tire with my tool, I simply slide the center hole of the wheel onto the tool which holds the tire/wheel and you simply rotate it until it aligns with the lugs, push it on, and loosely hand-tighten the lugs nuts, and simply remove the tool.
With the rods other folks use, you have to screw multiple rods onto the lugs, lift the tire and then align the wheel holes with rods, same as aligning with the lug nuts, the remove multiple rods from the lug studs.
It's much simpler to use ONE large center hole (where the center cap goes), than it is to align with several rods. However, both methods are easier than lifting a tire into the air and aligning with 5 lugs.
The center cap removal issue is a "red herring." When a tire is off, a simple push from behind and they pop right off without overstressing any of the individual prongs. Same with popping them back on.
So, I'll just quietly go back to reading because I got a lotta learning to do. Sometimes, it takes more than reading once.
Be kinder, guys. It's about cars---how can that be a bad thing if it's your combined interests.
