Sponsored by: Wheel Design
Tire mounting lug guide alignment tool
Old May 12, 2020 | 09:42 AM
robertbruce's Avatar
robertbruce
Default Tire mounting lug guide alignment tool
Who sells the C8 Tire Mounting Lug Guide Alignment Tool? Thank you.
Popular Reply
May 13, 2020, 09:02 AM
C8Jake's Avatar
C8Jake
I do it the old fashioned way...place wheel on the studs...no need for guide tools
Old May 12, 2020 | 09:47 AM
Phil1098's Avatar
Phil1098
https://reverselogic.ecwid.com/Exten...ools-p62332249
They look like jewelry in person, beautifully done.
Old May 12, 2020 | 10:18 AM
robertbruce
Thanks Phil. I just ordered a set. $75.00 They are worth their weight in gold! I have a set that I used for my C7 and would not leave home without them.
Old May 13, 2020 | 08:35 AM
cmonkey713's Avatar
cmonkey713
I have never seen this tool before, thanks for posting.
Old May 13, 2020 | 08:42 AM
Foosh's Avatar
Foosh
I bought this tire-changing aid for my C7 that is solid billet aluminum and fits in the center hub. Since I swap between summers and all-seasons at least twice a year, it's invaluable, and a little quicker. One end screws on the back hub, and the other end goes into the front.
I can't remember who sold it, but I thought it was clever. There are usually several ways to "skin a cat."
Old May 13, 2020 | 09:02 AM
C8Jake's Avatar
C8Jake
Old May 13, 2020 | 09:19 AM
Foosh's Avatar
Foosh
True, but does reduce the probability of damaging stud threads, as well as making things a little easier on one's back.
I have no problem doing it the old-fashioned way either, but once I used the tool I pictured above, it's a no-brainer because it's just easier.
Old May 13, 2020 | 09:52 AM
Phil1098's Avatar
Phil1098
I bought them because, while I would like to believe I've never had an oh **** moment, I have. I don't want to have the barrels of the wheels hit the caliper and ding the inside of the wheels or damage the red paint I paid for on my calipers.
Old May 13, 2020 | 09:56 AM
Phil1098's Avatar
Phil1098
The problem with this device, is the wheels have center caps, and while it would be handy to put wheels on, then snap the centers back on, not so much for wheel removal. Some center caps are a bitch to remove and only come off from the back side.
Old May 13, 2020 | 09:58 AM
Foosh's Avatar
Foosh
Not an issue with me, since I'm swapping an entire set of summers for all seasons and vice versa 2X a year. The caps are off the set going on.
The caps are ridiculously easy to remove when tires are off, but they're also ridiculously easy to remove with a no-scratch trim tool.
Old May 13, 2020 | 10:29 AM
VETFEVER's Avatar
VETFEVER
Interesting tool - it is a b!tch sometimes lifting a heavy wheel and lining up the studs...
It's either this, or buy lighter forged wheels....
Old May 13, 2020 | 10:31 AM
VETFEVER's Avatar
VETFEVER
And over time the plastic can become brittle and those little tabs that hold the cap in the centre hole tend to break....
Old May 13, 2020 | 10:42 AM
Phil1098's Avatar
Phil1098
+++ I've had that happen over the years too.
Old May 13, 2020 | 10:46 AM
Phil1098's Avatar
Phil1098
For that issue I have one of these too.
https://www.norcoindustries.com/prod...ler-dolly.html
Mostly for rotating the tires on the Grand Cherokee, they are heavy and big.
Old May 13, 2020 | 10:47 AM
Foosh's Avatar
Foosh
Not if you push gently with your finger on the center back of the cap. It barely stresses all the prongs evenly with a center push . I've been using the same 4 caps for 6 years and 2 tire changes a year now. That's 48 cap changes. They are as tight as when new.
Maybe it's an issue after 20 years or so, or with ham-handed gorillas, but man you guys are mired in minutiae.
Old May 13, 2020 | 10:51 AM
Phil1098's Avatar
Phil1098
I apologize if years of experience working on many different cars has provided us with our experiences. Not all cars I work on are new or even within six years of it. I'll crawl back into the gutter now where I apparently belong.
Old May 13, 2020 | 10:58 AM
Foosh's Avatar
Foosh
Thanks, I'd appreciate if you did that.
To Tire mounting lug guide alignment tool
Old May 13, 2020 | 11:03 AM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
It is ZL1 Addons " Mag Assist".......... I have it for the C7 Grand Sport we used to have. In all the excitement about trading in the C7 for our "pending" C8, I forgot to pull the front wheels off and remove the 2 machined pieces of each front wheel.
I called ZL1 Addons to see what they would charge me for another set of front wheel machined pieces and it was reasonable, $15 but decided I would wait to see if it would be usable on the C8, which I doubt. I still have the large tube piece as you show above.... not sure what I'll do with it. VERY nice product.
This time around, I bought a set of the Reverse Logic tools. Now, I just need the car. Been at 3000 since mid January.
Old May 13, 2020 | 11:07 AM
ByRiver's Avatar
ByRiver
I use a four foot 2x4 that I lay perpendicular to the brake rotor. I roll the tire up on the board then lift up on the 2x4 it until the wheel holes are even with the lugs then push it on. Saves my back, especially when trying to get my F150 tires back on. With this tool it seems like you still have to pick up the tire to get it on. Less fiddling but still requires muscle to install it.
Old May 13, 2020 | 11:16 AM
C8Jake's Avatar
C8Jake
https://zl1addons.com/collections/co...nt=28911136129
