Optional wheels question
My Z51 delivered in March in Ontario was regularly driven in 0 C temps. Nothing terrible happened.
The option wheels can be ordered through a dealer. Why not do it that way? Option or after-market are going to need a set of TPMS sensors if you intend to run 2 sets of wheels.
Unless the car is a daily driver I personally would not bother with A/S at all in your location.
most people want the aftermarket rims a little wider and with an offset that brings the wheel closer to the outer edge of the fender...
i think so far I saw a few sets of hybrid rims from vossen for about 2600 dollars and that might be where I eventually land.
you could do 19/20 s in slightly different offsets and get slightly larger rubber on the wheels which could help handling. PErsonally I think ill do that.
if I can mount stock rubber on them safely ill do it early. If I cant Ill go probably a year and a half or so as I daily my corvettes to the tune of about 12k a year.
Ive been driving various generation corvettes year round for decades. Im not afraid of the z51 higher performance tires in winter weather as these are NOT cup2 tires.
itll be fine as long as the snow isnt more than a few inches. We usually get 100 inches of snow each winter but last winter here was nothing but one light storm.
once I buy aftermarket rims or a set of take offs at a great discount as there will be a ton of them available on craigslist or these forums...ill pony up a set of dedicated snow tires for my standard rims gm ships with the car..
this plan has worked for me for many, many years.
id recommend this to anyone asking for a plan of action ..
check out the vossen wheels ..right now Id suggest they are a better value and a better looking larger wheel than the gm slightly over priced oem offerings.
good luck and take your time.
the z51 tires are as I said not cup2 tires...they are more balanced and can easily be used year round except for deep snow etc...
anybody with common sense knows how to drive with lateral cornering capability of .73 in wintery conditions worst case scenerio.
back in the 1960s and 1970s that was close to the maximum adhesion capability of standard vehicles like pony cars etc...and we all made a ton of hp back then too..
no abs brakes, no traction control either.
we used to just be more sensitive to handling limits even with extremely low adhesion capability compared to todays technology.
be conserative in expectations of the p4s z51 tire in the winter until you get a dedecated snow winter tire wheel setup on the stock rims and in my opinion youll be just fine.
all seasons are in my opinion a waste...
two sets of wheels and tires, one being the stock free set with winter tires and the other being higher performance summer tires is pretty much free other than the extra set of wheels and sensors..
you basically are just extending the life of your summer tires during the months of december , january, fevruary and march by using dedicated winter snow tires in those months.
btw I dont bother with runflats when replacing tires myself.
i prefer the lower unsprung weight and slightly less cost of non runflats.
ymmv
The swapover point occurs at 6 deg C or 43 deg F. So winter tires are better when you have sustained temps below that where summer tires lose flexibility and some grip. But as I said before - still quite useable.
