Checking oil level
The engine is dry sump, so the dip stick measures the level of the dry sump tank mounted to the front of the engine. And running means oil is circulating in the tank continuously. The dip stick has a pretty wide range of hash marks and nothing says its a quart low. So as long as the oil level is within the hash marks, its good.
Today, I checked the oil level. It now has 4000 miles and it was changed at 2000 miles and the level was in the middle of the hash marks after the oil change and now at 4000 miles. Does it mean it has not burned any oil? I don't think that that is exactly correct. Just means while the oil is circulating, the level in the dry sump tank is in the correct range. Different way of thinking of it.
Really no different that a "slushbox" automatic transmission, car at idle and dip stick reading very consistent!
Wife's BMW has no dip stick and uses sensors with the engine running to define the level. Takes a bit of time but you get a value.
Problem is, do you know what level it was at right after the oil change? Make sure vehicle is on level ground too obviously.
I decided to change mine early after the 1500mi break-in rather than 7500 miles. The dealership put a sticker on the window that the vehicle was filled with "DEXOS".
I need to contact them because the large barrel of DEXOS oil I saw next to the lift where my vehicle was being worked on is NOT the correct oil for this vehicle. I should be DEXOS 2, Mobile 1 0W-40 ESP. Why does the window sticker say "DEXOS" ?
Only change noted was engine oil color prior to oil and filter change. Originally looked almost clear. At 6,000 miles looked like good quality Tupelo honey.
Zero oil consumption so far. Now at 8,400 miles.
Now the problem. The tech working the oil change bay can just pull the handle on a gun that pumps oil from a 55 gallon drum in his service bay OR go over to the parts department, wait if there are others there than lug 8 quarts of the proper 0-40 ESP dexos 2 oil to his change bay. Hmm, they gat paid commission for how many cars they service! What do you think many do? In fact with the C7 up to 2019 the Owner's Manual said that cheap oil blend (dexos certified) was OK to use. Do doubt the Service Manager who runs a business bought whatever the cheapest is as that is all that is required for 99.5% of the cars and trucks they service! That is one reason why up to now I have done my own oil changes.
However I now go to a small Chevy Dealer 30 miles from home with a great Corvette tech who is the only one who touches Vettes. Trust him. However I will call the parts department the week prior to making an appointment and be sure they have the 0-40 ESP Mobil 1 oil AND the DCT filter in stock! Also a quart of the DIF fluid for the ~8 oz needed to replenish what is lost with the filter change. Will call in 2 weeks as I'll be at 12 months end August.
You can also ask your service manager to verify that they only put 0W-40 in Corvettes, but if you don't trust the dealer, maybe you should look for another one.
So does our engines eat oil? how bad is it?
Engine does not eat oil. Added none at ~4000 miles when I had my 12 month required change.
I have Engine oil, DCT fluid and Coolant temps displayed in the left of my dash (your choice on what you have,) Engine oil gets to ~175 in about 10 minutes. Won't get much higher. My Coolant temp stays between 175 and 180F. Both oil and DCT fluid have liquid/liquid heat exchangers that use coolant to maintain their temps so all will be close UNLESS Tracking of very aggressive driving.
Liquid/Liquid heat exchangers use engine coolant to keep engine oil and DCT fluid close to coolant temp in "normal driving."
(I Post Pics for those who want to to know WHY when I make comments. IF not you for some of the Silent Majority who view Threads BUT Don't/Won't post! This Tread is a good example 100 X more folks viewed versus the Vocal Minority who Posted. Shows lots of interest!)
“If 0W-40 dexos2 oil is not available, 5W-30 dexos1 full synthetic engine oil may be used for street use.”
Source -> https://www.chevrolet.com/content/da...l%20072120.pdf
