Sponsored by: Wheel Design
View Poll Results: Have you had a valve spring failure?
Yes
13.22%
No
86.78%
Voters: 174. You may not vote on this poll
Valve spring failure prevalence
Old Oct 4, 2020 | 08:09 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
No. 2995 built June 3rd. 3,000 miles. I'm going to continue to enjoy it and not spend alot of time worrying.
Old Oct 4, 2020 | 11:07 PM
Phil1098's Avatar
Phil1098
Originally Posted by unklejoe
You can start by not making **** up. By posting this you are claiming it's a valve spring failure that caused it. That car was delivered to the owner in early March. It wasn't a June - September build.
Old Oct 4, 2020 | 11:14 PM
Phil1098's Avatar
Phil1098
Drove mine again today, 1,600+ miles 3313 VIN early June build.
Pretty surprised by the tires, I have Z51 PS4 on the car and it was low 50s today, the gauge did finally go from cool to normal, but I didn't perceive any decrease in grip and did a couple 0-60 runs that felt like when it was really hot out.
Old Oct 4, 2020 | 11:46 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
6841 built 8/4 , 4000 miles no issue
drove 1050 miles in a 13 hr period without issue
Old Oct 5, 2020 | 06:46 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Early failure. One guy had his fail while he was actually taking delivery of the car.
It's really ridiculous. These cars are ticking time bombs. GM needs to do a ******* formal recall.
Hmm, you started this Thread BUT do you have a C8 or just one the Porsche lovers who have fun knocking the C8?
I don't use fowl language on the Forum as you appear to like- all I can say is, "F*** Porsche!" Don't give a crape what they do!
Now for those with C8s, mine was built early September, VIN xx 8002. Have no idea when the engine was built in Tonawanda NY where the valve springs were installed.
My C8 has 700+ miles and has hit 6500 rpm a number of times and works fine. My "guess" from the one pic we have of a broken spring and failures occurring with low miles this is "probably" and internal defect NOT a bad batch of springs improperly heat treated. Tonawanda probably checks batches of springs for spring force at installed height and max lift. Easy to do and probably a tight spec. BUT a statistical sample will not pick up a few springs with internal defects. In fact a defective spring could even pass that test. Best place to check spring wire for defects is when it's rod as it enters the wire drawing machine.
IMO GM would be foolish to have a recall replacing a large number of good springs!
Old Oct 5, 2020 | 09:01 AM
GoldRose85's Avatar
GoldRose85
I asked in another forum and never got an answer.
Is there a particular cylinder that the spring breaks in, or is a random cylinder?
Is it only one spring that goes bad or is it multiple springs.
Most post are only one spring that broke, If tested out OK, could another spring break?
I can't understand if it is a bad batch, why are only one spring in an engine breaking?
Old Oct 5, 2020 | 09:15 AM
JTBogus's Avatar
JTBogus
6/27 build, 7/03 in service, 5500 miles. Been to 170mph + a number of times on a LSR track.
Old Oct 5, 2020 | 10:13 AM
JerryU's Avatar
JerryU
IMO, it's one and for this reason, look at the one pic we have of a broken spring:
It's a clean break not from a weak spring, which might be expected form say bad heat treating. My "GUESS" is its a metallurgical defect, like a nonmetallic inclusion etc. That would occur in some from a batch of bad rod the wire was made from. That batch of spings would be sent to the Tonawanda engine plant where they would be placed on the engine. Best GM can do is define about which egines might have used springs made from that bad batch of wire. Probably a small percentage and would cause short term failures.
Time will tell. But if over 500 miles looks like you may be safe.
Clean break not a weak spring!
Old Oct 5, 2020 | 10:52 AM
Phil1098's Avatar
Phil1098
If memory serves (no guarantees ) I think I have seen #5 and #8 but don't know what other cylinders have had one. Seems to be random, and not head related, but truly spring failing from what Jerry has described.
Old Oct 5, 2020 | 02:40 PM
7thgeneration's Avatar
7thgeneration
Who is the vendor for these springs ? Surely they don't come from China ? They can't make dog snacks right for crying out loud !
Old Oct 5, 2020 | 03:06 PM
rider1's Avatar
rider1
#6551 took delivery August 13, 3150 care free miles. No issues other than the TPMS which I will have them look at when the oil gets changed.
Old Oct 5, 2020 | 04:06 PM
Neverenough14's Avatar
Neverenough14
6183. 7/27 Build. 440 Miles. Not yet...but I am smack dab in the middle of the range of cars that were ID'd as possible problem cars, so it enters my mind every time I take it out.
Old Oct 5, 2020 | 04:55 PM
  #33
JerryU's Avatar
JerryU
I thought dogs were a snack in China!
Old Oct 5, 2020 | 04:58 PM
  #34
Phil1098's Avatar
Phil1098
Careful posting something funny Jerry, you'll be called a racist.
Old Oct 5, 2020 | 05:06 PM
  #35
JerryU's Avatar
JerryU
Been there a few times. They do eat dogs! In fact was at an outdoor market and they had scorpions on a stick!
Old Oct 5, 2020 | 05:10 PM
  #36
Phil1098's Avatar
Phil1098
I said that people that live in Mexico are called Mexicans and got in trouble. Just saying.
  #37
GoldRose85's Avatar
GoldRose85
Thank Jerry and Phil for the reply...
I still don't understand why only ONE spring is breaking.
If it is a bad supply batch, shouldn't more break per engine.
Or is there a special valve spring per cylinder because of the cylinder de activation? that is breaking?
To Valve spring failure prevalence
Old Oct 5, 2020 | 05:14 PM
  #38
Phil1098's Avatar
Phil1098
Not a special spring, they are all the same. GM probably gets them by the thousands, the same spring goes in truck 6.2 liter motors and 5.3. If a few bad ones are in a container holding thousands of them it's just spring lottery at that point.
Old Oct 5, 2020 | 05:33 PM
  #39
RKCRLR's Avatar
RKCRLR
Say a 1000 springs were made from a particular draw of wire and that wire had one defect in it. Then the spring made from the section of wire with the defect in it will break.
It may not necessarily be an out of spec defect that is causing the problems. Nothing is perfect and the wire is likely allowed a certain number of (very small) defects within a certain proximity of each other. Normally these defects wouldn't cause a problem. The problem is when a defect is large enough to case a stress concentration that generates a crack. And sometimes cracks are "self healing" when they get to an area of lower stresses and they no longer propagate. Usually the center of the wire in a spring is under less stress than the exterior surface.
Ductility normally has an influence on crack propagation. If the heat treatment was performed such that the springs are too "brittle" then defects that wouldn't normally be a problem could cause crack initiation and propagation.
I'm not a spring expert but it would be interesting to hear from one.
Old Oct 5, 2020 | 06:04 PM
  #40
pietro c7's Avatar
pietro c7
June 10th build,3307
1300 miles,no issues.
