Sponsored by: Wheel Design
View Poll Results: Have you had a valve spring failure?
Yes
13.22%
No
86.78%
Voters: 174. You may not vote on this poll
Valve spring failure prevalence
Old Oct 4, 2020 | 03:17 PM
unklejoe's Avatar
unklejoe
Default Valve spring failure prevalence
I'm looking to better understand the magnitude of this valve spring failure issue in the C8. I know it affects other cars, but I'm mainly interested in the C8.
I see some people claiming that it's rare, but I'm seeing more and more cases every day, and given that there really aren't that many C8's out there, it's sort of alarming. I know, the car has a warranty, but I'm still not exactly thrilled about the idea of my brand new $80k car leaving me stranded after a couple hundred miles.
Some will say that you only hear about the failure cases and never the non-failures, but on the other hand, I'm sure there are failures that go unreported and just get fixed without publicity.
So, this is a simple poll: Have you had a failure or not?
Feel free to post the last 4/5 digits of your VIN so we can get an idea of affected dates.
Popular Reply
Oct 4, 2020, 11:07 PM
Phil1098's Avatar
Phil1098
Originally Posted by unklejoe
You can start by not making **** up. By posting this you are claiming it's a valve spring failure that caused it. That car was delivered to the owner in early March. It wasn't a June - September build.
Old Oct 4, 2020 | 03:26 PM
Zymurgy's Avatar
Zymurgy
Moderator
No. 09199 1500+ miles.
Old Oct 4, 2020 | 03:42 PM
orclubduck's Avatar
orclubduck
Zymurgy,
You need to let your C8 have a heat cycle...you are going to have the first C8 to hit a million miles :-)
No.05235 7/15 built 500 miles...
Jeff
Old Oct 4, 2020 | 03:48 PM
john91498's Avatar
john91498
I belong to the C8 Owners Facebook page. There's literally a case a week and the latest car only had 129 miles on it.
Old Oct 4, 2020 | 03:50 PM
WalterSobchak's Avatar
WalterSobchak
#3587 6/15 built 4000 miles
Old Oct 4, 2020 | 03:55 PM
Zymurgy's Avatar
Zymurgy
Moderator
Originally Posted by orclubduck
Zymurgy,
No.05235 500 miles...
Jeff
I put those miles on during the 4 day road trip home from the NCM.
Old Oct 4, 2020 | 04:20 PM
sblvro's Avatar
sblvro
8606 288 miles no failure whatsoever.
Old Oct 4, 2020 | 04:52 PM
unklejoe's Avatar
unklejoe
Two more data points: VIN 10842 and VIN 10977 had failures and were both produced on 9/18, three days after the supposed 9/15 cutoff window indicated in GM's TSB.
Old Oct 4, 2020 | 05:23 PM
ArizonaZ06's Avatar
ArizonaZ06
Active Streak: 90 Days
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
No for me. Vin #3760 1247miles
Old Oct 4, 2020 | 05:33 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Is this an early life failure or can the springs fail at any time during the life of the car?
Old Oct 4, 2020 | 05:38 PM
Racer86's Avatar
Racer86
3959 built 6-21, 2300 miles. No issues with car
Old Oct 4, 2020 | 05:46 PM
ArizonaZ06's Avatar
ArizonaZ06
Early life failure. Most members feel if you get past 500 miles you should be good.
Old Oct 4, 2020 | 05:50 PM
unklejoe's Avatar
unklejoe
Early failure. One guy had his fail while he was actually taking delivery of the car.
It's really ridiculous. These cars are ticking time bombs. GM needs to do a ******* formal recall.
Old Oct 4, 2020 | 05:57 PM
Phil1098's Avatar
Phil1098
Not going to happen. They will not spend millions of dollars to "fix" 10,000 cars that don't have a problem. From 1999 to 2005 Porsche had OVER 10% of every standard 911 engine go BOOM at various miles some as low as a few thousand all the way to tens of thousands of miles and they never recalled them. Those were 100% catastrophic failures that took a $20k of THE EXACT SAME DESIGN that was just as likely to go BOOM as what just came out! Put in a new motor and wait for the next one to let go.
Old Oct 4, 2020 | 06:52 PM
unklejoe's Avatar
unklejoe
Yes, the Porsche IMS thing from 15 years ago was bad...but we're talking about brand new cars having a potentially catastrophic engine failure with less than 100 miles here. One guy had his fail while he was at the dealership taking delivery of the car.
BMW did a recall for the defective VANOS bolts on the N55 engine, and the failure rate of that was much lower than with these valve springs and usually occurred after the warranty period. There are anecdotes to be found either way.
There's also a chance that the cost of preventative replacement will be somewhat dampened when you consider the fact that most of these failures occur early on - well within warranty period, which means that if the valve spring _does_ fail and the keepers happen to pop out, the engine is totally trashed and will be replaced on GM's dime.
A set of valve springs probably costs GM on the order $15 plus a couple hours of labor to swap them out (it's not hard to do on these motors). Much cheaper and easier than replacing an engine.
It all comes down to whether they can really identify the bad batch or not, or how widespread the issue really is.
Old Oct 4, 2020 | 06:58 PM
Silamanajik's Avatar
Silamanajik
#10309, built 9/15, 550 miles. So far so good.
Old Oct 4, 2020 | 07:02 PM
thill444's Avatar
thill444
The valve spring issue is across a bunch of V8’s and GM vehicles. Like Phil said, no way will they recall them all if say less than 1% are affected. It’s just math. Still cheaper to replace a handful of motors.
To Valve spring failure prevalence
Old Oct 4, 2020 | 07:29 PM
Phil1098's Avatar
Phil1098
All those Porsche had an issue from day one too, it just took a while for it to show its hand. Have yet to see a LT2 have a catastrophic engine failure due to a broken valve spring. They pull (push) it into the shop, swap the springs from above, and send them on their way. When the IMS failed, the chains went slack, cams jumped time, valves smashed into pistons, and those motors were junk on the spot. Not one of these had that happen yet. Sorry but it seems like an over reaction to the problem. There is no way GM would spend millions for no reason, neither would you.
Old Oct 4, 2020 | 07:53 PM
gthal's Avatar
gthal
Is there an affected VIN range or is it all VINS?
5,000km and no issue.
Old Oct 4, 2020 | 07:56 PM
unklejoe's Avatar
unklejoe
