Sponsored by: Wheel Design
Mag Ride Question
Old Nov 12, 2020 | 12:17 PM
Zhan94's Avatar
Zhan94
5th Gear
Default Mag Ride Question
Hi all, never owned Corvettes or any GM before, ready to order C8.
Question about the mag ride, is it actually an additional switch or button that you can push or set up in the computer? Or is it something that's being built into the car that's 'always on'? I'm confused because I keep seeing people say how good it is that with a switch of a button you can go from a GT cruiser to a sports car, but I thought all the modes already come with the base trim anyways, like going from Touring to Sport. Can I put it this way that mag ride makes each mode even better and you don't have to do anything?
Hope my question makes sense, thanks in advance.
Popular Reply
Nov 12, 2020, 12:20 PM
CitznFish's Avatar
CitznFish
If you have mag ride it is always on. The switching being referred to are the different modes of the system. Weather, tour, sport, track, etc. Each mode is configurable across multiple systems, steering, brake, transmission, power delivery, exhaust loudness, etc.
There are great videos from GM that give an overview of the system.
Old Nov 12, 2020 | 12:20 PM
CitznFish's Avatar
CitznFish
Old Nov 12, 2020 | 02:25 PM
rrsperry's Avatar
rrsperry
Don’t worry about it. Get it, and then figure it out. In my opinion, it should be a must have. Yes, it’s that good.
Old Nov 12, 2020 | 02:45 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
Without MSRC you still have all of the modes (Weather, Touring, Sport Track, My, Z) but there’s are no suspension setting changes available. Modes can still change exhaust (if you have NPP performance exhaust), braking, throttle response, etc. With MSRC there will also be suspension setting changes available with the different modes.
Old Nov 12, 2020 | 07:20 PM
Zhan94's Avatar
Zhan94
5th Gear
That's exactly what I was looking for, thank you!
Old Nov 12, 2020 | 11:25 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
Here’s what the owner’s manual says about the suspension mode setting:
“Suspension:
This setting adjusts the firmness of the suspension in the vehicle. Suspension adjust stiffness of the shocks and/or springs. The ride is more comfortable at lower settings and is stiffer at higher settings for better control.
Tour, Sport, Track”
So the three suspension settings available if you have MSRC are Tour, Sport, and Track. Your selectable modes, “My Mode and Z Mode” could be set to any of those 3 settings.
In the table in that section of the manual it also says the Suspension setting is only available with Magnetic Ride.
Also says this about MSRC:
“Magnetic Ride Control (if equipped)
Adjusts the shock dampening firmness based on driving conditions to improve comfort and performance.”
Old Nov 13, 2020 | 11:15 AM
dinows33's Avatar
dinows33
I gave my final build sheet yesterday and was not going to order the mag. The guy talked me into it and also quoted the re sale value. I guess when your spending this kind of money whats another 1800 for a super option. This option is so popular they now let you order it on any vehicle. When it came out a year ago I think only the z51 offered it
Old Nov 13, 2020 | 11:26 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Good question and it is confusing!
This pic from the Owner's Manual may help BUT you'll have to study and NOTE, the main difference with MRC, as noted where I highlighted on yellow, is RIDE.
Fact is the base car with no MRC and Z51 without MRC changes many variables when you rotate the **** and go through the various DRIVE MODES. BUT only if you have MRC does the ride change from softer to harder. Frankly since the springs and sway bars don't change and from my experience, it's like going from a modestly stiff ride to a very stiff ride BUT it's the shocks changing not anything else.
As was noted, it's also always on (has to be or you would not have shocks) and makes shock adjustments based on a number of sensors and inputs several times a second.
Old Nov 13, 2020 | 11:58 AM
Sin City's Avatar
Sin City
2020 C8 of the Year Finalist - Unmodified
One interesting thing we don't talk about much is Z mode. I set my car up for My Mode and with the Mag ride, you can make the car less harsh when driving over typical roads with potholes and uneven surfaces.
Then in Z mode, set it up to be more firm. With one button press it instantly changes the personality. Without Mag ride, it changes but it would not effect ride quality or stifness.
Old Nov 13, 2020 | 12:07 PM
tooold2race's Avatar
tooold2race
I had Mag Ride on an earlier C7 and thought it was a waste of money because the difference between the ride and that of my friends C7's without it was hard for me to distinguish. I opted for it on our HTC and although I've not driven a C8 without it, I believe I'd have to study the owner's manual to tell the difference. In my opinion, the 'seat of the pants' difference is not justified in the cost.
It's really up to you to decide based on your driving and feel.... NOTE: If you keep the car for a long period of time you need to realize that replacement shocks are VERY expensive!
Old Nov 13, 2020 | 12:40 PM
JerryU's Avatar
JerryU
Originally Posted by Sin City
One interesting thing we don't talk about much is Z mode..
With Z MODE you can set all controllable variables wherever you'd like INCLUDING POWER, which you cannot do in MY MODE, Touring or Sport. In fact as I have mine set the big difference is POWER set at Track.
When setting POWER to Track you don't get more BUT it controls the way it's applied. You can set ride to the softest MRC allows like Touring. NPP, Brakes, Steering can be set to whatever you'd like.
WITH POWER SET TO TRACK:
  • The car will upshift at much higher rpm than when in TOURING, SPORT or MY MODE.
  • It will seldom shift past 5th gear (Note 4th and 5th are also OD ratios) providing engine torque with modest throttle increases WITHOUT downshifting.
  • It will NOT go into V4 mode.
  • When braking it will downshift at higher rpm as it downshifts and rev match perfectly in each gear.
  • Note, if desired to can still use the shift paddles. So if it's in 5th and your cruising, pull the upshift paddle and you can shift to 6th or 7th. If making an aggressive turn you can downshift at whatever rpm you'd like as you brake.
Old Nov 13, 2020 | 12:54 PM
RKCRLR's Avatar
RKCRLR
Have you tried the different modes? In my C7 the difference were very noticeable to me, especially on rough or winding roads. Not much difference on smooth roads.
The standard OEM front shocks are $95.89 on RockAuto (the rears aren't yet available). The front MSRC shocks are $247.79. So $400 vs $1000 for a set of 4.
And the shocks are covered under the 3 year bumper to bumper warranty. And, if you are really concerned, they are also covered under the GM extended warranty.
Old Nov 13, 2020 | 01:21 PM
Bill Dearborn's Avatar
Bill Dearborn
As others have said it changes suspension stiffness with changes in driving modes but it is always on. The big advantage is it can dampen suspension movement better than standard shocks and quicker than the older mechanical variable shocks. The best display of what it can accomplish is in a GM marketing video from 2003.
The display showing the differences in suspension performance starts at 1.25 in the video. It is more than a way to adjust how stiff the shocks are. It varies it's response based on road conditions which means it can make the car more controllable by the driver when unexpected road conditions are encountered.
Bill
Old Nov 13, 2020 | 05:37 PM
Jeffthunbird's Avatar
Jeffthunbird
You don’t need it. My C8 z51 rides great and feels like a sports car. I wouldn’t want to soften the ride.
Old Nov 13, 2020 | 05:54 PM
Yammyhaha's Avatar
Yammyhaha
Maybe it's not needed, but it sure is nice to have.
To Mag Ride Question
