What's the damage? tiny and below drivers side headlight, can it be fixed?
Oh ****. This was a big issue on C7’s especially 2017’s. A lot of front and rear bumper paint peeling / cracking on the panel seams because they were not properly cleaned / prepared before painting. This was supposedly fixed. I guess not
It’s too bad the ppf installer didn’t wrap the edges with the film. You can clearly see in your photo that there is zero clearance between those two panels, so when the car/panels flex for any number of reasons, they’re rubbing together. The paint needs to be touched up AND those panels aligned better. Good luck.
The other thing on your car that you can see in the pic, which is true on my cars with ppf (Xpel specifically), is their pre-cut kits leave a good bit of space unprotected.
The other thing on your car that you can see in the pic, which is true on my cars with ppf (Xpel specifically), is their pre-cut kits leave a good bit if space unprotected.
of you wrap the edges over two panels that touch you're screwed. Been there.. don't that..
This started happenong on 2016 or so when they changed the panels again from 14 15. Must be the lighter material or something. Go back and read the articles about the C7 composites getting even lighter for 2016. That's when I started noticing this myself as well. It sucks.
Robert:
I had this same problem on my 2015 C7. The dealer was able to adjust the panels and fix the paint; you can't even see where it used to be. So yes, it is fixable.
Originally Posted by DrivesWithTwoFeet
.....Ridiculous that this is still an issue.....
Couldn't agree more. Six years later and they still can't get their act together on it.
Car was fine when I first got it this was after a ppf install
my car is a 2020 built dec 10
Hmmm mine built on December 10th also. Can you take a photo a couple feet further out? I will post a picture of mine in the same spot this evening to compare gaps. I will loose my mind if I find splits in the paint like that. See the difference?
