Sponsored by: Wheel Design
Record MPG?
Old May 17, 2021 | 09:45 AM
heisnuts's Avatar
heisnuts
Default Record MPG?
We just returned from a weekend in Sunriver in central Oregon. I still can't get over how comfortable this car is on longer trips. Each way is about 4 hours and even with no stops we arrived each time no worse for wear than when we started. On the way back I happened to notice that between traffic going around 60 mph most of the time and then a construction zone that brought us down to a 40 mph zone for about 20 miles or so, the trip computer for the current trip after an hour and a half of driving and over 70 miles showed 37 MPG. Like a lot of others have pointed out on this car you really cannot tell when the car switches between V8 and V4 mode when driving without looking down on the display.
Old May 17, 2021 | 10:09 AM
CGZO6's Avatar
CGZO6
49.2 MPH average speed.
Old May 17, 2021 | 11:27 AM
BTT's Avatar
BTT
At highway speeds, my best over the past 50 miles has been about 29.3 mpg. If anyone didn't know, you can change the distance over which it does it's calculation in the dash.
Old May 17, 2021 | 11:30 AM
foo.c's Avatar
foo.c
It's a lot more fun if you can get your average to 1/10th of that.
Old May 17, 2021 | 12:02 PM
C8J's Avatar
C8J
That may be higher math for some.
In V4 at lower speeds (30-50) mpg is significantly higher. I don't think it is due to aerodynamics; curious how large (wider) tires affect mpg as one goes faster. If typical passenger size tires were installed, mpg would be almost 40% higher on the highway.
Old May 17, 2021 | 12:04 PM
plmmd's Avatar
plmmd
since delivery 2009 miles ago 12.7- Thanks to consistent Zeros on the My Chevrolet safe driver app
Old May 17, 2021 | 01:29 PM
WalterSobchak's Avatar
WalterSobchak
That's the correct way to drive it! 👍🏻😂
Old May 17, 2021 | 01:44 PM
heisnuts's Avatar
heisnuts
LOL. So true. I look forward to lower numbers in the future now that I am through break in. I was just rather amazed that it went so high even given the light driving conditions. It didn't stay that high for long after we were back up to 65 mph for a while. It went all the way down to 35.6 mpg after another couple hours.
Old May 17, 2021 | 04:13 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
My 700 hp '08 Z06 gets 4 mpg around town and 2 at the track.
Old May 17, 2021 | 04:46 PM
wrmiles's Avatar
wrmiles
You will do even better if you get gas and/or reset it at the top of a long downhill stretch.
To Record MPG?
