Rearview mirror question
contacts and blame those rather than my age. My 18 year old daughter prefers using the camera mode when she has driven the car.
You may want to try switching modes and then adjusting the mirror to see if you can find a better combination.
In addition to the focus issue the distance perspective in the camera mode is very different. Thing seem twice as far away as they really are. Do you also have that sense about camera mode?
Yes, it does take a second or two for your eyes to adjust when you switch from the regular rearview mirror to the camera view.
I really miss the rearview camera when I have the top down on my Corvette. Because of the design of the convertible, you only see the top half of cars in the rearview mirror. The camera gives you a panorama of what is behind you. I really wish the engineers could have devised a way to make it rearview mirror camera active when the top is down.
This is the issue I have the most problem with and have not found any setting that eliminates the distance issue . I can tell something is behind me however do feel comfortable judging the actual distance nor can I make out what kind of car is behind me at any distance except someone that is extremely close
Hopefully someone has found a solution because the sideview mirrors can not pick up something directly behind you because of the shape of the body. After 3 months I'm use to the change in focus required however the distance is no better then the first day .
With the HTC you can only use it with the top up, which begs the question: can the brain get used to both near and far focus of the rear view mirror?
Maybe in a year I'll have an answer.
Been perfect for a year. In fact I have it set with a wide view much like the convex passenger side mirror. Yep as that side mirror states (and the Meat Loaf Song) "Objects in the TV Mirror are closer than they appear!" Frankly it's so good I find I'm using the side mirrors less- NO NEED. I can see the cars coming up fast on the lanes either side of me who will soon be in my blind spot! IMO best thing since sliced bread! Helps me keep my 60 driving record of not having an accident with another car!
Try it and see if it's not better. Yep in a vert, understand with the top down you have to use the real mirror and view is fine. With the wife's SUV, which I drive often, I have to adjust the center mirror when I get in! No big deal!
PS: When I got my C8 Coupe I tried using the "real mirror." Rear visibility was worse than my C7 Z51 and Grand Sport (which had a limited view of the rear as the Stage 2 Aero option had side extensions on the spoiler.". Made the rear view almost as bad as a rag top Vette!
PS: Although I need little correction for distance I wear my glasses from when I get up until I go to bed. In the Sunny South they make great sun glasses and are perfectly clear indoors.. Wife had cataract surgery and instead of a few pairs of progressive transition glasses (for different frames) now has at least 4 pairs of prescription reading glasses and about 5 pairs of sun glasses! I thought my $1200 frameless, progressive, transition, glasses were expensive but no match for what she has invested!
