Sponsored by: Wheel Design
Rearview mirror question
Old Jul 30, 2021 | 12:21 PM
  #41
Mike's LS3's Avatar
Mike's LS3
Originally Posted by 2vette2
When I glance at the rearview mirror when it is in camera mode, it takes my eyes a couple of seconds to focus. This does not happen in normal mode. Anyone else have this issue?
Normal and if you wear glasses for nearsightedness, unless you have progressive lenses, it's worse.
I will try "tilting" the mirror towards myself as suggested.
  #42
rowala's Avatar
rowala
I had trouble initially because I wear reading glasses normally to see close up, but found if you don't really try to focus but rather look at the overall picture, it is ok. Does help with the blind spots.
Old Jul 30, 2021 | 03:22 PM
  #43
Red C8 of Jax's Avatar
Red C8 of Jax
I have the same problem, I wear reading glasses, I noticed it you adjust the camera to the close up view your view is much better. You still have a wide view.
Old Jul 30, 2021 | 03:57 PM
  #44
Zymurgy's Avatar
Zymurgy
Moderator
Note that there are three adjustments that can be made to the camera mirror: Brightness, Field of view (zoom) and Tilt.
Old Aug 3, 2021 | 10:59 PM
  #45
MarZZ's Avatar
MarZZ
Originally Posted by plmmd
Ok - ophthalmologist here- first no depth perception in mirror or camera view as that is a flat image (whether projected or reflected) in either case and binocularity not an issue. the bigger issue is user age- The camera represents a image at a closer distance that is a fixed point of focus- The mirror is a reflected image that has the distance focal point. So with a camera image if youre over 40 years old it will be progressively difficult to see without using near assistance (multifocal contact, progressive or bifocal/trifocal glasses). the mirror image is easily viewed with distance glasses. The further you are away from 40 the more difficult the camera is to see unassisted.
In regards to cataract surgery - there are implants that correct astigmatism as well as multifocality These options should be discussed with your surgeon pre operatively as many patients are selecting spectacle independence - though it is expensive
How about using top focal glasses like shooting glasses? Or just buy the adhesive readers and install them along the top of your glasses. Just a thought.
