Sponsored by: Wheel Design
C8 Engine Bay lights
Old Oct 31, 2021 | 01:25 PM
unodonjuan's Avatar
unodonjuan
Default C8 Engine Bay lights
I was trying to see if anyone had any suggestions on which is the best engine cabin lights and where to order them from?
thanks UNO
Old Oct 31, 2021 | 05:36 PM
Greg G's Avatar
Greg G
I purchased the lights from GM parts direct
Lamp 84238354 $29.25
Lamp 84238355 $292.5
I also ordered the correct connectors and pins to wire the lights.
Connector from Mouser Electronics Their # 571-1-1823608-5 you need 2
Pins 571-175265-1 you need 4
I did not wore them in yet. Still deciding where to get the power, probably the fuse box.
If you decide to go this route I have extra connectors and pins. I will sell 2 connectors and 4 pins for $12 shipped.
Old Oct 31, 2021 | 10:28 PM
JTBogus's Avatar
JTBogus
I'd like those connectors & pins. PM? Thanks, JT
Old Nov 1, 2021 | 12:57 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
thanks UNO
Depends how often you plan to use. I only use at night when someone asks to see the engine! Not very often so my remote operated, battery power lights are just fine. And cheap on Amazon.
Night View
Lots available on Amazon. Changes all the time so my 1 year old info won't help- just look, pick size you want. Mine said waterproof and use 3 AAA batteries.
Just one of many colors available on the remote. Bit blurry as not as bright as white!
Old Nov 1, 2021 | 01:49 PM
unodonjuan's Avatar
unodonjuan
Night View
Can you give me the full description so I can look for it on Amazon. I couldn’t find it.
thanks,
Uno
Old Nov 1, 2021 | 02:07 PM
JerryU's Avatar
JerryU
Funny, actually found the same brand I used 1 year ago! There are so many of the same thing sold under different names. Probably all from the same factory in China!. Can buy 2 for $15.
Creatrek LED Tea Light Submersible Tub SPA Lamp Color Changing/LED Lotus Light Flower Lamp for Garden Pathway Vases Bowls Coaster Pond Fish Tank Fountain Ice Buckets Bathtubs Hot-tubs
You will want to look at this PDF as I show how I mounted using two pieces of 3M Dual Lock I had. But can use several pieces of double sided tape stacked to deal with the slight recess on the back side: Engine_Lights.pdf (netwelding.com)
Old Nov 1, 2021 | 06:14 PM
unodonjuan's Avatar
unodonjuan
Th
Thank you
Old Nov 1, 2021 | 11:36 PM
hypntyz's Avatar
hypntyz
https://www.corvetteforum.com/forums...t-install.html
To C8 Engine Bay lights
