Sponsored by: Wheel Design
teflon coating
Old Nov 2, 2021 | 09:58 AM
bs0604's Avatar
bs0604
Cruising
Default teflon coating
someone suggested I consider aftermarket "teflon coating". Is this a good idea?
Old Nov 2, 2021 | 10:19 AM
Bluehinder's Avatar
Bluehinder
Makes the car faster, more slippery in the wind.
Old Nov 2, 2021 | 10:51 AM
Majestic94's Avatar
Majestic94
It’s great when you’re cooking eggs on your hood and don’t want them to stick,
Old Nov 2, 2021 | 10:55 AM
wfoZ06's Avatar
wfoZ06
Go with the copper-clad as seen on TV.
Old Nov 2, 2021 | 11:04 AM
smb33076's Avatar
smb33076
Default coating
I think you mean Ceramic Coating. I did it on my C8 and now never have to wash it. Just hose down and wipe off with microfiber towel. No soap needed so far in two months and shiny as ever.
Old Nov 2, 2021 | 01:53 PM
Esoteric Detail's Avatar
Esoteric Detail
Supporting Vendor
Teflon 'coatings' had a brief period in the sun and are still used, predominantly in the Auto Dealer environment it seems. Protection strategies evolve and although Teflon still has a place as an ingredient in car-care products (generally noted as PTFE), it's more of a complimentary piece of the pie as opposed to the foundation of it.
Ceramic coatings have come into their own over the past 10 or so years, and while there is definitely some 'over-stated' marketing associated with them, they do indeed have many positive aspects.
​​​​​​Like many things, whether a ceramic is for your depends on your maintenance preferences and, more importantly, your expectations for the products. Some folks like wax, some sealants, some coatings and some enjoy the benefits of PPF (Paint Protection Film); there is no universal right or wrong answer but rather just what is right for *you*.
A note about the difference between true ceramic coatings and some spray sealants marketed as 'coatings'; in general if it's coming out of a spray bottle, it's a ceramic-infused sealant and not a genuine ceramic/quartz/glass coating.
What are the differences between ceramic and spray coatings? FAQ by ESOTERIC!
Some quick vid links:
Will I be disappointed with a ceramic coating
What coating manufacturers don't want you to know
5 Common myths about ceramic coatings
Making the right decision! Wax vs ceramic coating
Do I need to remove old ceramic coating before applying more?
Should ion be so inclined, DIY'g a ceramic coating application is well within the capabilities of an interested DIY'er. Like many things, the preparation is the key to the best outcome. A quick outline for the best prep is:
Chemical and Physical Decontamination
Paint Polishing
https://youtube.com/playlist?list=PL...rog0VQzKhef0ZW
Wipedown with Panel Prep
Apply Ceramic Coating
Aftercare
Ceramic Coating Aftercare Guide
There are some fantastic and easy to use coatings available to the DIY hobbyist and we prefer the Kamikaze line for ease of use and overall performance. ISM 1.0 is notable for its tendency to produce a deeper, wax-like glow as opposed the the more candy/sharp gloss of many coatings while Miyabi is a more sharp, reflective glow.
DIY or professionally installed, ceramic coatings can be very beneficial if your particular situation and personal preferences align with their strengths.
Old Nov 2, 2021 | 03:31 PM
SoCal C8's Avatar
SoCal C8
Livin the Life
2024 C8 of the Year Winner - Modified
Obviously you meant ceramic coating…….
teflon coating is for politicians.
Old Nov 2, 2021 | 08:07 PM
BigF6B's Avatar
BigF6B
Or "Granite Stone"....
Old Nov 3, 2021 | 03:54 AM
GTUnit's Avatar
GTUnit
Teflon coat the seats for easy exit
Old Nov 3, 2021 | 04:50 AM
TexasMark's Avatar
TexasMark
Vastly quoted fallacies on the internet:
  1. A ceramic coating is "genuine ceramic/quartz/glass". This is not true. It is a polysiloxane coating. A molecule that contains Si and O but also organic groups, typically methyl groups.
  2. MOHS hardness of 9, i.e. hard as quartz/glass. Not true. The "9H" quoted on the bottle refers to pencil hardness, not MOHS hardness. Pencil hardness of 9H is approximately the same hardness as the catalyzed polyurethane clear coat used on modern cars.
Primary benefits of automotive ceramic coatings instead of wax coatings:
  1. It doesn't need to be applied nearly as often (it is more durable).
  2. It is highly hydrophobic (repels water). Might be more hydrophobic than wax.
I use it myself.
To teflon coating
