Sponsored by: Wheel Design
C8 Quick Jack Recommendation
Old Nov 22, 2021 | 07:15 PM
tractman's Avatar
tractman
2024 C8 of the Year Finalist - Modified
Originally Posted by Phil1098
Didn't really confuse me, the TL series just goes a few inches higher vs the SL. Still don't see the safety issue of TL vs. TLX with a C8.
Being very safety conscience......I will only use the GM designated lift points.....I bought the extension for the one I had to reach the lift points then it wouldn't fit under the car without getting the car on some sort of riser....wasn't going that route so I sold the one I had bought the longer to match up with the recommended lifting points without doing something makeshift.
Old Nov 22, 2021 | 07:49 PM
bjniceguy's Avatar
bjniceguy
i had the shorter version for my C7. I bought the extensions to work with my C8. Only issue is it is really close to slide under car. I bought a set of Flat Stoppers to drive on 1st (gives you a 1.5" lift (could also build something out of 2x12 with angles on edge I guess). This lets me see exactly where my blocks are hitting (helps with my comfort level)
I hang the extensions side ways on wall to keep out of way
Old Nov 22, 2021 | 09:48 PM
avigar's Avatar
avigar
Don't the Flat Stoppers ramps get in the way when you try to slide your Quick Jack in place? Is yours the QJ 5000 SLX?
Old Nov 22, 2021 | 10:13 PM
blueapplepaste's Avatar
blueapplepaste
Originally Posted by DTOM
Sounds like a great deal. I'd like to order one as well. Can you post the link?
Sure: https://www.quickjack.com/blackfriday/
Was $1480 shipped for the 5000TLX. I was kicking myself for not grabbing the Costco sale. But that would have also needed the extensions. So for just a little more this deal gets the latest model.
Old Nov 22, 2021 | 10:19 PM
bjniceguy's Avatar
bjniceguy
Home depot sells the shorter ones ($1300) & the extensions f($200) for about $1500 total but don't show the longer ones on their website. Shipping to store is free, but my extensions took about 10 days to arrive
Old Nov 22, 2021 | 10:26 PM
bjniceguy's Avatar
bjniceguy
i have shorter version & the flat stoppers clear by 3" or so both ends
Old Nov 23, 2021 | 08:04 AM
Phil1098's Avatar
Phil1098
Lifting a C8 safely is making SURE you are using the REAR lift points. Just look at the pics of cars that fell off of lifts, EVERY single one was lifted too far forward. With the high weight bias in the rear, as long as the car is lifted at the rear lift points, it makes no difference in the least that the front lift is a few inches back. Glad you're happy, but saying it's done for safety sake is implying that those that use the standard length QJ don't care about safety or are unsafe, and that's just not true.
Old Nov 23, 2021 | 10:06 AM
Racer86's Avatar
Racer86
5000EXT reaches the lifting pucks at both ends perfectly. No BS, no extensions
Old Nov 23, 2021 | 11:38 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
The TLX is a replacement for the 5000EXT. mostly the same, lifts 3" higher. I just ordered mine to take advantage of the Black Friday $200 discount.
Old Nov 24, 2021 | 09:59 PM
at7000ft's Avatar
at7000ft
Can the 5000TLX be kept when lowered in the center of the garage and the C8 parked over it? Rather than hanging on a wall between uses?
Old Nov 24, 2021 | 11:26 PM
MilesC8's Avatar
MilesC8
Me too. Just ordered thr 5000TLX with the $200 off. Thanks for sharing!
Old Nov 25, 2021 | 11:55 AM
1050High's Avatar
1050High
Could I ask where you ordered these? Can’t find the 5000TLX on Costco.com?
Old Nov 25, 2021 | 11:57 AM
  #33
Phil1098's Avatar
Phil1098
https://www.quickjack.com/blackfrida...SAAEgLS9PD_BwE
Old Dec 9, 2021 | 08:43 PM
  #34
1050High's Avatar
1050High
I too sold my 5000SLX - took about a $200 hair cut. Just received new 5000TLX. Slid the rails under my C8 for test fit, and it appeared to be a stretch to reach both lifting points? Perhaps the "radius" swing motion when the QJ are lifted will better center rubber blocks under pucks? Has anyone actually used the 5000TLX and confirmed them to be adequate length? I'd like to know before I do any more unboxing or hydraulic set up in case they need to be returned. Thanks so much for any insight this group can provide.
Old Dec 9, 2021 | 08:48 PM
  #35
blueapplepaste
The specs say it’s same length as getting the extensions on the regular model, which plenty have confirmed the 66” on those is sufficient. It’s also same length as the old EXT model which people say it works.
So at least on paper the new TLX should absolutely should work.
I got my 5000TLX, but it was missing parts so am waiting on those. And also waiting on my car (TPW next week though!).
Old Dec 9, 2021 | 09:00 PM
  #36
1050High's Avatar
1050High
Right Costco didn't have the 5000TLX so I ordered direct from Quick Jack.
Old Dec 9, 2021 | 09:03 PM
  #37
1050High's Avatar
1050High
Also got a $200 Black Friday Sale discount online thru QuickJack. Net cost was $1480 delivered.
To C8 Quick Jack Recommendation
Old Dec 9, 2021 | 09:17 PM
  #38
shatter's Avatar
shatter
St. Jude Donor '22
Quickjack had a 15% off code (SEMA2021) earlier in November that I used to get a 7000TLX. I was surprised when I saw their Black Friday deal was not as good.
Old Dec 9, 2021 | 11:59 PM
  #39
Caymanspyder's Avatar
Caymanspyder
Originally Posted by JVi
With the SLX versions, do what was done in this setup ;put the rubber block under the rear jack point and leave the space at the front of the C8 where there is less mass.
Your exactly correct, I have the 5000 SLX and it works perfect, The weight is in the rear, lifts it no problem at all. You can set jack stands in the front lift points to make it "safer" if you choose, but it is stable
Old Dec 10, 2021 | 08:16 PM
  #40
1050High's Avatar
1050High
Anyone tried to set 12 in tall Race Ramp Wheel Cribs below tires as safety net when lifted on QJ 5000DLX to highest lift point? Not sure the bottom of the C8 tires get 12+ inches off the ground to accommodate Race Ramp but the safety & soundness configuration sounds sweet!
