DCT-Problems/Solutions
I've been watching your posts about leaks. I am sorry you are dealing with that.
I'm interested in the statement "cylinder 1-3-5-7 failure". My 2020 has been back to the dealership three times since new. It's a fairly early car. Here's the timeline:
My 2020 must be a “Tigger” when it comes to fuel injectors. I’ve researched this site and the web in general and I don’t find other C8 Corvette owners reporting fuel injector problems. My car’s in the shop for the third time with what appears to be another fuel injector problem.
Timeline:
Took delivery of my 2020 on July 3, 2020. I could not connect for software updates at my house, or “automatically” while sitting near stronger wifi signals. Took to dealership for software updates and they had the car for 10 days while they worked with GM Tech. Let me say, I love my dealership and the tech is topnotch.
Nov. 2020:
Just limped home in VIN 3688, check engine light, rough running, "Service ESC" and "Service Traction Control" showing. After turning off engine smelled "burnt" and passenger side intake fan ran for a long time. Car has 895 miles on the odometer.
Update:
Dealership says it's not a broken valve spring and they can't replicate the problem. They're talking to GM about the codes being displayed. I'll go to the dealership on Monday to get a better understanding of what is/is not happening. I seriously felt the symptoms I was having matched what others were getting with a broken valve spring.
Update: 12.2.2020, the dealership apologized for bungled communication, GM has authorized replacing all valve springs.
Update: 12-5-2020: the dealership and GM Tech diagnosed my problem as a "faulty fuel injector," TAC suggested a compression test and a leak down test. Results within normal specs. All valve springs were inspected with no issues found. #5 injector was replaced and GM authorized all sixteen valve springs be replaced for "customer satisfaction." Car number 3688 did not have a broken valve spring...but, the customer (me) is satisfied. Thank you Integrity Chevrolet and GM.
New problem: March 26, 2021
Car #3688 back in the shop with same symptoms, check engine light, "stumbling" rough running, "Service ESC" and "Service Traction Control" showing. After turning off engine smelled "burnt" and side intake fans ran for a long time. (my dealer Tech did mention that Service ESC and Service Traction Control codes display for many different engine issues).
This has happened at 25mph, 43mph and 55mph. I usually drive in Sport mode, but tried all modes on way back home. Seemed to occur in all drive modes. I may have been mistaken, but, I felt that when I held the shift paddles in neutral mode and revved the engine it didn't miss...not 100% sure of this. I've never done a hard launch...but, have "floored" it a few times on long stretches.
Been in for a week with no progress, the one mechanic I really trust has two Corvettes (not C8s) ahead of me. I'll update with status when fixed.
April 12, 2021
Leaking fuel injector on cylinder #3, fouled spark plug, #3. Replaced both.
This was my second fuel injector problem.
New problem: December 6, 2021
We were on vacation and the car hadn’t been driven for about two weeks. Stuttered while I backed out of the garage to do a little cleanup. December 8th, 2021 had a dealership appointment to replace DCT filter and change DCT fluid. Leaving my driveway the car did the same familiar missing/surging, in addition to something new, abnormal pausing between transmission shifts. I drove on to the dealership.
Car has been at dealership for six days now. Only update from my tech is that there is some problem in the 1-3-5-7 bank and GM Tech has dealer tech sending specific diagnostics for review.
Additional notes: The Corvette has always used Pure (brand name) premium gasoline. The Corvette is always on battery charger when garaged. The car has about 2100 miles on the odometer. I’ve since found out that "Service ESC" and "Service Traction Control" pop up for just about every C8 problem you encounter.
I still love this car…but, I’m being tested. BTW, I’m #1 on the list at this dealership for a C8 Z06 order. I’ve been a Corvette enthusiast since my first one in 1968.
Update: December 14, 2021. Replaced injector #1. It was late when I picked up the car. Paperwork wasn't complete and filed. I'll get a copy tomorrow. Three injectors, all on the right bank. I suppose I should have insisted they replace #7 and get it over with.
**Could this be the same as the above stated Cylinder 1-3-5-7 problems? Anyone?
Thanks,
Daniel (Dan) Smith
River City Corvette Club – Chattanooga
NCM(L) Ambassador
I bought a 2001 Z06. The forums were filled with stories of wildly high oil consumption. The stories were true. Chevy analyzed the reports and the parts involved and concluded the rings and cylinder bore liners were incompatible. They made a running production change in April 2001 and my car, built in early June of 2001 had those production changes. I knew that because Car & Driver published that information so I was comfortable buying one. I kept that car for 18 years. It never leaked or burned any oil. See my web sit at:
http://www.rjsmith.com/z06.html
Was there an initial problem? Yes. Did Chevy correct the problem? Yes, rather quickly because it was costing them money. If there were DCTs that had the high failure rate implied, Chevy would be swamped with corrective action under warranty which would cost them big bucks. I think they would find the problem and heads would roll. Junior heads, granted, because managers are never responsible it's always the grunt engineers. And they would have made running production changes.
With the plant shut-downs due to COVID and supply issues, you would think the engineers would have plenty of time to analyze dealer feedback and failed components and would have made immediate changes to the design, if applicable, to the assembly procedure ― don't use a hammer to install that seal ― or any other issue exposed. The real questions are: What caused the initial problem?; Is it fixable?; Was it corrected and if so when?; Which specific assembly number had the changes initially applied?
I don't know if these "reports" are true, or whether they are intentional disinformation from disgruntled people who can not, for whatever reason, buy a C8. Yes, it happens.
Ray
If only 2% have had problems, that's 1200 transmissions with about 60K units produced, which is kind of a big deal, even though the odds of any particular individual having a problem are pretty low.
In my industry (commercial aviation), if we had a 2% problem rate with a particular component, the type of aircraft with that component would be grounded without a known fix.
Tell me though, without those voicing the issues that you of course do not think exist, how would I find these class members? I would not pay for mail sir and I sure as hell would not do anything for free...you see I already did my pro bono in law school.
You may be on to something though, I give you that.
And I wasn't being facetious about a class action lawsuit. If there are as many DCT failures as intimated, there would be ample grounds for liability claims. For example, was Chevy aware of the problems with Tremec's manufacture and assembly of the transmission? Did they identify the specific issue? When? What was their response? Have they taken corrective action? Issued a product recall or warning?
It's interesting that reporting indicates Chevy will assume production of the transmission from Tremec. Was that because of systemic issues at Tremec? Did they not follow Chevy engineering instructions?
You could get all that in discovery, and make it public, even if you don't prevail in court.
Ray
Ray
https://www.corvetteforum.com/forums...post1604395279
If memory serves me correctly, DCT issues were on the radar screen very early on, and may be been identified in testing before customer production began. Early mag tests with pre-production cars referred to GM making "tweaks" to the DCT before actual production began.
Ray
Seriously? The same gang that thinks JFK Jr. is still alive and will make an appearance at Dealey Plaza? You want me to believe anecdotal evidence from them as engineering proof of failure? I'm sure they think alien technology was used at Area 51 to engineer the Tremec DCT. And the aliens played a trick on Tremec.
Ray
Here’s a very quick search result re: 2022 transmission issues: https://www.corvetteforum.com/forums...850-miles.html
Re: your lack of reading comprehension; the OP asked “have any ‘22s experienced transmission issues” to paraphrase. S/he didn’t ask how prevalent the issues were, just if there have been any reported. The answer to the OP’s question is yes there have been ‘22s with transmission problems. That’s not debatable.
You’re also incorrect about the LS1/6 oil consumption issues. The issue wasn’t fixed until the 2002 model year (I don’t consider 4 years “rather quickly”) and had been occurring since the introduction of the LS1 in 1998. I personally had 1 LS1 replaced under warranty in my ‘99 WS6 TA, and my ‘99 Camaro SS was also experiencing the same issue. Additionally, I personally knew at least 10 others in my car club in Phoenix, AZ, who had LS1s replaced under warranty between 1999-2002. Considering the size of the group at the time, 11 engine replacements was a significant number.
When one starts introducing irrelevant information or unrelated comparisons (i.e. JFK, aliens), they’ve lost their argument.
The start of your last paragraph sums it up nicely, “I don’t know if these reports are true”. Exactly, so any effort to refute them just makes you look silly
My reading comprehension is not a problem. It was good enough to get me an engineering degree. The best you can do is "Exercise Physiologist & College Professor.". Do you give massages?
Your Phoenix car club? Your bio says you are in Prosper Texas.
I had a 2001 Z06. There were running production changes made in April 2001. That's a documented fact. Those changes were carried over to the 2002 model year. My car had a June build date so it had the revised ring and sleeve combination. I kept that car for 18 years. Do you truly believe I would have kept a car that burned a quart of oil every 500 miles for 18 years? I sold that car and bought the Ferrari F430. See my web site for details.
I could afford to buy the C8 at $20,000 over MSRP and did so because I can. Apparently you can not. I guess there isn't much money in being an "Exercise Physiologist & College Professor."
And like so many people who talk loud, you're anonymous. I'm not anonymous, my name is Ray Smith, in Costa Mesa, CA., and I'm in the phone book.
Ray
Ray
Ray
Ohh snap, I like this guy.
Let's not all forget it is Christmas Eve though!
The point I was trying to make is that if there are as many failures as has been intimated ― though not documented here ― attorneys would be all over this issue. We're talking about an American icon in the Corvette. You remember how much press the Ford Pinto received? Or the Chevy Corvair? Hell, that was a case study in school, how trailing throttle over steer can kill and how it affected GM. Ralph Nader made his bones on that one.
So if there is a problem ― and I have standing on this issue since I own one ― then I would like to know the facts. I would file suit to be made whole, meaning I get my money back and my F430.
My intention was not to sword fight, but to ascertain whether this is a systemic problem, an isolated problem, or misinformation. I would think that if an owner had a DCT issue, he/she would be more than happy to air that grievance here. And if that were the case, the forum would be flooded with those reports if the issue is as bad as some claim. What I want to see are specifics as to what the part failed, when that part failed, were there aggravating circumstances, how was the problem corrected?
And the guy from Texas? He has no standing. That's politics. He's a Tea Bagger/Trumper. I'm not.
I did not have bone spurs.
Oh, and Merry Christmas. I'm an atheist, I'm in it for the winter solstice.
Ray
As far as the c8 it all will come down to how gm handles issues.
Going back to the original post mentioning the Acura….we too had one that failed. The extended warranty applied to cars with less then 100k miles. Ours had 103k when it failed. Acura replaced it on their dime.
Would you expect gm to do the same under similar circumstances?
I don’t plan to have a c8 outside of warranty. My dealer tells me gm is asking them to return all filters pulled in the fluid change. Something is up.
