Sponsored by: Wheel Design
C8 Problems
Old Dec 29, 2021 | 11:14 PM
Phil1098's Avatar
Phil1098
Originally Posted by Stangslayer
Not hardly, transmission fluid is extremely flammable. Would you drive with a known gasoline leak?
So it wasn't until you took it in for service that you found out it had a leak and after 7,500 miles it wasn't on the garage floor? Mine has the same level of leak, the pan is wet and there is a film on the belly pan, I drive it every day that I can. You're over reacting to the whole flammability thing, I don't give mine a thought and there has been zero cars that have caught fire from DCT fluid leaking. Mines parked until spring, and I will either get a new pan gasket and hopefully by then they will have a revised version. If they don't, I will have it replaced with same style but new, and I'll seal it externally.
The reality is, it's not a mid engine Molotov cocktail. I hope you don't believe it started leaking a mile before you took it in for service, it's been leaking for thousands of miles. Every day you have been driving it there has been fluid weeping out, you just didn't know about it.
Old Dec 30, 2021 | 01:41 AM
Rapid Z's Avatar
Rapid Z
Are you a lawyer? Not as easy as you think.
It is, the car is worth at least $10k more than you paid for it. Get it fixed sell it to CarMax or trade it and buy the BMW. You really can’t get hurt right now buying a C8 Corvette. However the BMW resale is another thing.
Old Dec 30, 2021 | 04:13 AM
C5racecar's Avatar
C5racecar
I'm just amazed that Chevrolet does not have a fix for a leak, like a new oil pan or a better gasket. Usually they can fix these issues instead of replacing the entire trans. That has to be an expensive trans, and a big cost of labor hours to replace it.
Old Dec 30, 2021 | 08:15 AM
Stangslayer's Avatar
Stangslayer
Originally Posted by dohabandit
Maybe you can top off the DCTF via the air breather tube periodically. Problem is, how fast is this leak?
Also, the DCTF is pretty expensive. If you think the 0W-40 ESP Mobile 1 oil is high priced, check the prices on the Pentosin FFL-4, haha!
So you never saw any oil on the garage floor? No oil on the aluminum plate? No CEL or codes? No trouble with the driveability?
I would seriously want to SEE that leak before I ditched that car to the dealer. Put a clean catch bucket underneath, open the drain, lets see how much fluid is in there. Replace the fluid back into the DCT, top it off, put some tracing powder around the porosity issue area and drive it for a day or two.
Then drain it back out again and compare the level, did the tracing powder show a leak down the side? It could still be a pan gasket issue maybe?
and I would do that why?
Old Dec 30, 2021 | 10:08 AM
hokieZ's Avatar
hokieZ
To drive you car until the transmission arrives. It’s up to you what you want to do though.
If you are really this upset, get that car fixed under warranty then sell it while you can make a profit. It seems clear you will not be happy with the Corvette no matter what now.
Old Dec 30, 2021 | 05:47 PM
Stangslayer
Got the bad news today! Took my 2021 C8 in for the 7,500 mile service to be told the DCT is leaking and will need to be replaced.
Seriously, I thought the DCT issues were resolved by now.
Late June 2021 build VIN XXXXXXXXXXXXX8006
Guess I should have gone with the BMW.
just a follow up. The same DCT is on the GT500 and also has the same issues as the C8.
Great job Tremec.
Old Dec 30, 2021 | 06:26 PM
Phil1098's Avatar
Phil1098
Great job Tremec.
And this is 100% incorrect. Great follow up. One of these things is not like the other.
7 Speed TR9070
8 Speed TR9080 transaxle
Old Dec 30, 2021 | 06:54 PM
JDSC8VETTE's Avatar
JDSC8VETTE
why replaced? They should be able to fix what’s leaking without replacing the transmission.
Either way you should sell and buy your BMW. A very good friend of mine had a couple BMW’s and will never own another one. In his words there were way too many issues for what they cost him. Good luck.
Old Dec 30, 2021 | 08:01 PM
dohabandit's Avatar
dohabandit
If the "case" has a porosity issue, they have to replace the entire transmission.
There is a region where the metal is not flowing through the mold very well and leading to leaks. They can seal it using a high pressure sealant, but that requires taking the entire transmission apart, also requiring the DCT to be removed. If they are going to go that far, they will probably just scrap the case and perhaps re-use the internals.
So basically, if you have a porosity issue type leak, it's a DCT swap that is required.
If it's a pan gasket/seal, that's another matter entirely which is why I suggested he digs a little further to CONFIRM where the leak is coming from. I wouldn't just take their word for it without asking if they did the tracing powder test or not.
If it was a very slow leak, I would add some DCTF via the breather tube and just keep driving it until the DCT part comes in.
Old Dec 30, 2021 | 08:03 PM
dohabandit's Avatar
dohabandit
7 Speed TR9070
Probably better to say it is an "evolution" of the TR9070.
But it is a very different transmission. All new case design. Integral diffs, shallow pan, different solenoid / valve body locations, +1 gear, etc etc...
The TR9080 is such an abortion that McLaren is using it now too. Who knew!
Old Dec 30, 2021 | 11:18 PM
Caymanspyder's Avatar
Caymanspyder
Drive it and enjoy it, Transmission fluid is NOT extremely flammable, It is just seeping, if it was actually leaking at an alarming rate, you would of seen it on the floor running between the panels. You can drive it for several months before you would even have to think about adding fluid. And who cares, it is being replaced anyway, the sky is not falling, You will be fine.
Old Dec 30, 2021 | 11:24 PM
Milo4g's Avatar
Milo4g
Mine has been at the dealer for 2 weeks and they said it would be at least 3 before the transmission guy gets to it. I had the thought of fixing under warranty and selling it, but then a new one is more expensive, and the warranty price will go up too. Lemon law same thing, in Florida is just 3 weeks out.
Im thinking if anything the extended and factory warranties will have shell out fixes and cash for years to come. I will get my extended warranty money back for sure.
Old Dec 31, 2021 | 07:17 AM
  #33
Stangslayer
Different configuration, but same internals with the same problems.
Old Dec 31, 2021 | 07:24 AM
  #34
thrilled's Avatar
thrilled
If your not happy sell it for a BMW.
Old Dec 31, 2021 | 07:28 AM
  #35
kitesurfer's Avatar
kitesurfer
Originally Posted by Avanti
Of course, there is a sticky thread above with the exact same title with over 1700 posts.
but your post is the most helpful! many thanks for your post!
Old Dec 31, 2021 | 07:38 AM
  #36
Sdk8103's Avatar
Sdk8103
So you think BMWs don't have their issue? LOL, check out their forums.
Old Dec 31, 2021 | 09:21 AM
  #37
dohabandit's Avatar
dohabandit
So basically the problem is "gears". Okie dokie!
Was the TR9070 recalled or have a class action lawsuit? I must have missed it!
To C8 Problems
Old Dec 31, 2021 | 09:53 AM
  #38
DarthMaliceM1's Avatar
DarthMaliceM1
Where have you seen reports of GT500s having transmission issues at the same rate as the C8? I have done searches looking for this very thing and have pretty much seen the opposite. I am a member at Mustang6G too and there would be complainers out in droves if that were the case...instead I see one thread about a guy with a leak and another where they compare the trans from both with the GT500 having far fewer reported issues. I will say at least the transmission fluid fill is much easier on the GT500 which is a bonus based on how often it has to be changed. The filter change is about the same. I really like everything about the C8 except what I am seeing around this DCT. Maybe when I am ready to look into a two seater in a few years, they will have this ironed out.
Old Dec 31, 2021 | 10:17 AM
  #39
Phil1098's Avatar
Phil1098
This coming from the guy that won't drive his car because the DCT fluid is highly flammable.
Old Dec 31, 2021 | 12:49 PM
  #40
dohabandit's Avatar
dohabandit
My understanding was the TR9070 had some overheating issues initially. There are some videos of mustangs going into limp mode during a race due to overheating. Maybe this is why the TR9080 increased cooling capacity along with the fact the differentials are integral to the DCT now which probably adds heat.
