launch mode
From the actual warranty
. Collision, fire, theft, freezing, vandalism, riot, explosion,
or objects striking the vehicle
. Misuse of the vehicle such as driving over curbs, overloading, racing or other competition.
https://www.chevrolet.com/content/dam/chevrolet/na/us/english/index/owners/warranty/02-pdfs/19_CHEV_WM_.pdf
https://www.chevrolet.com/content/da...9_CHEV_WM_.pdf
Yikes, this sucks.
I'll wait until 1500 miles. Not because of the above post, but just to be extra careful.
If it blew up at 890 miles, I can't imaging another 610 would magically do the trick.
They do think things will break which is why they say to avoid track events till 1500 miles. Any violation of which can result in being turned down for a warranty claim. I don’t know for sure, but I’d bet that’s something they can easily pull from the computer.
I was the one who started it for the first time when it was ready to come off the line. NFW do they run it anywhere max power! Sure part of the test includes running it through the gears, can see that on a number of video's. I was answering the statement that it isn't stressed more in Launch Mode than experienced at the factory!! That is BS.SIDEBAR (The highest stressed Engine part are Valve springs. Worse at High RPM)
This is the reason when I was breaking in my engine I was carful to have the valve springs treated very carefully for 500 miles. As would GM! Especially as my September 2020 C8 was in a time span when some valves were breaking usually under 500 miles. They are the most highly stressed engine part AND at high rpm the harmonics cause increased loads.
Quoting: The valve spring is the most highly stressed engine part. Just how much torture are we looking at? To put things in perspective, Lunati manufactures high-tech connecting rods with a 250,000-psi tensile strength. The rod "rarely sees even 50,000 psi of stress under real-world operating conditions" (20 percent of its rated load, or a 4:1 safety margin). But it's common for a valve spring to continually operate at half or slightly more than half of its rated load. "A spring that's rated at 300,000 psi routinely will see loads approaching 150,000 to 190,000 psi every cycle. Nothing else in the motor continuously runs at 50 percent of its ultimate strength—and it needs to do that, in long-distance racing, for millions of cycles." That's not even a 2:1 safety margin—so, yes, valve springs really do operate right on the edge in a high-end motor!
Break-in New Valve Springs: It’s important for new valve springs to be broken in properly. Upon initial start-up limit the rpm to 1500 to 2000 rpm until operating temps are reached, Then shut off the engine and allows to cool to room temperature. This will usually eliminate early breakage and prolong spring life.
Note the Extra Spring Movement as RPM Increases. Causes Higher Stress
It always amazes me at the responses....Lots of knowledge here...
It's my DD and I intend to keep it for a long time. So what's another 900 miles if it could possibly, theoretically, even just a hair of a chance, help with the longevity of the transmission?
I read every one of these threads and this has been debated by owners for years now. Why isnt there a definative answer from Chevy?!
And yeah, I agree, debated for years. In the end, it's just a car. I'll likely take it to the automatic car wash if it's too cold to wash it in the driveway anyway.
Also the very high stresses very high tensile strength valve spring wire (for perspective, it can can exceed 250,000 psi while the steel in the bridge can be less than 50,000 psi) as all metals, has microscopic defects that can grow into cracks. Proper break-in at limited rpm can have those microscopic discontinuities blunt at the ends (like drilling a hole at the end of a sharp crack.)
Yep with proper cylinder honing and finishing racing engines can be broken-in on a dyno (no trans/dif gears to worry about) with some initial lower rpm runs and the oil/all parts up to temperature and with their thin lower friction rings high rpm break-in might provide slight extra power. BUT big difference in a racing engine and road engine, re finishes such as cylinder homing for power versus life. Also remember when we sponsored Richard Petty for >15 years (our folks were supplying welding training in addition to welding and cutting machines.) Being a gearhead I would go with them and talk with his crew chief, Dale Inman. Great fun guy. Recall I was asking about the oil used. He mentioned it was like a very light weight to reduce friction and gain hp. I asked it that heavy enough to protect the engine. He said for the 500 miles we need!
PS: Can't expect GM to say all the things you shouldn't do i.e. not launch mode for XXX or no jumping your car or doing NASCAR winner sustained Donuts to protect the DCT! Nope can't advise on all stupid things folks could do!
In fact the "ONLY" thing I have seen quoted by a GM rep as "WHY" add an extra 2 quarts of DCT fluid for Tracking was a spokesman giving a talk at a Carlisle Evet who said it's because if Tracking going downhill and turning the fluid can go to the top of the case! Guess, if that was the issue they could have also said no "Jumping Your C8!" It was also said by a Youtuber it was done because GM found someone doing foolish NASCAR Winner Sustained Donuts!
