Being a curious sort, and having read comments about the heat in the trunk, I put a remote temperature sensor in the trunk of my 2022 3LT Z51 HTC. The point where I started driving was about 10:15 am. Somewhat of a surprise is that the temperature actually rises after one stops driving and shuts off the engine. I parked at about 2:00 pm and the high temperature was closer to 2:45 pm.
I'd be curious as to what ambient temps were during that period, and how much they increased during the 5 hours of driving. Would also be interesting to correlate the ups and downs with your driving conditions (e.g., were the highest temps noted while stopped in traffic, or while at high speeds). And I wonder what occurred between 10:30 and 11:00, when temps rose 30 degrees, and between 14:00 and 14:30, when they jumped by 22 degrees.
Interesting data nonetheless. Don't carry ice cream or chocolate in the trunk.
I would love to know the temp of the frunk from just sitting in the sun all day while parked.
In my limited experience thus far (only had car since Jan, and things just starting to heat up), I would say it seems comparable to a typical trunk on a normal car that’s in the rear. Definitely gets pretty warm if left in the sun. But doesn’t seem any worse either.
Yeah, pretty clear the front-trunk is where things are to be kept. The rear is just for the top or golf clubs.
Unless you're a DoorDash driver, in which case, that's a feature.
The frunk is way too inconvenient to use on a regular basis. The double button press and handing to force the hood down so hard to get it to actually close make me rarely use it. Only time I use the frunk is if the trunk is full or if I have food that needs to stay cold.
Tadge says put the beer in the frunk and pizza in the back. I've been on some long drives with mine and noticed it gets warm, but I am sure it is nowhere near the temps you hit.
RE: my MY23 trunk is crazy hot. I''m comparing it to admittedly old school 87 Turbo Esprit (mid-engine turbo 2.2 liter) and C8 rear trunk is MAGNITUDES overall hotter than I realized.
I went down the street - about 3 miles - to get a document notarized.
Afterwards, I put the single sheet of paper in a plastic folder, put on top of jacket in rear trunk and drove home the 3 miles back.
That sheet of paper was SO HOT on a short trip - WOW!
Question - has anyone looked at creating a thermal liner for C8 rear trunk?
On my 87 Turbo Esprit I use thermal bags for sensitive items - the passenger side rear trunk is actually far cooler than any part of a C8 rear trunk.
The front trunk on Esprit has central radiator and spare tire; some parts get hot there too.
I'm thinking of sewing a big thermal 'sleeve' that hangs on the cargo net hooks.
It's not a solution as much as workaround.
We discussed this at our monthly Corvette club meeting. Long drives even at high ambient, the temps are fine. In extended stop and go, they get very hot (metal on folding chairs barely touchable. 2021-2023 MY seem to be much cooler than 2020s.
Rule: no cosmetics or other meltables/toiletries in the trunk!
I think a couple of CorvetteForum sponsors sell a kit. Here is one.
GM addressed adding insulation to the trunk. The reality is all insulation does is slow down heat transfer. So for shorter trips, yeah, it would stay cooler. But after enough time (depending on the R value) you'd reach the same temps anyway. Insulation won't make it cooler, it will make it warm up slower. Depending on how you insulate, you may get the added effect of keeping it warmer longer too. Think of how outdoor ovens work. They take a while to get hot, but once they do, they stay hot.
I learned that early in my ownership. The beer and ice cream go in the frunk on the way home from the store.
While insulation only slows heat transfer, it can help keep the trunk cooler if installed in just the right places. Some people were thinking if they insulated all trunk surfaces it would make it better. But the reality is you need to insulate the surfaces that are exposed to the heat sources and leave the cooler places uninsulated to allow the heat to escape. Also, the insulation with foil surfaces will help with thermal radiation.
