I have a 22 C8 coup, Z51, mag ride, 1700/miles. The car had the "lights always on" problem. The dealer reprogrammed two modules, which fixed the problem. However, when I pulled into the garage, and turned it off, I heard a high pitched buzzing sound coming from under the frunk. New sound. The sound lasted about 30 seconds to a minute. Pulled the frunk covers, started the car, shut it off, and the buzz started again. traced it (I think) to some module attached to what appears to be something to do with A/C. Unfortunately I am unable to identify car parts any more, so really not sure. Was wondering if anyone else has experienced this sound?
My front lift will sometimes make a buzzing sound and sometimes not. I have it set to lift in my driveway. But, after the car is shut off, it lowers, and sometimes buzzes. After the car is off, the lift will immediately start to lower, unless a door is opened. Even so, it will (according to the manual) only temporarily stop lowering. Then it will lower anyway.
My car also makes other more subtle clicking and soft humming noises from time to time after turned off, or after first turned on. I ignore them
Thanks. Rarely use the front lift. So, I don't think it's that. But, you make a good point, probably not anything I need to worry about. As my doctor always says "Let's just keep an eye on that". Thanks for your input.
This is certainly not what we like to hear, jrcslc. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 C8. To do so, please send an email to socialmedia@gm.com with ATTN: jrcslc/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information. www.gm.com
If you do find this out, please let us know. My wife's Escalade has done this since we got it. I took it to the dealer and they stated they could not hear it (which I find impossible). It has not had any other effects that I can tell, but it is really concerning when you are in the garage where it seems extremely loud. It is higher pitched that the self-leveling suspension and lasts much longer than that. 30 seconds to a minute I would estimate. It comes from the front as well.
The headlights have a built-in fan and can run after shutdown, similar to the radiator fans. Interesting enough, I noticed the same thing from my passenger side light. Later I discovered that the high beam on that same light did not work. Dealer changed the light and I have not heard the fan run since then. I would check my high beams just to make sure it is not a related issue. But the fans running is normal, especially after night driving.
I also have a 2022.
I knew they had a fan. But, I never heard them make a noise - I did not know that the even made a noise when the running. That is interesting information.
We have a Honda CR-V that occasionally makes a buzzing sound with the engine off. Had me concerned until I read this from a service bulletin:
Noise from Under Vehicle: This noise is caused by the vacuum pump inside the fuel evaporation leakage check module (ELCM). Depending on conditions, the pump will come on for about 15 minutes about 5 to 10 hours after engine shutoff.
Made perfect sense after I read it! I have no idea whether the C8 has similar equipment, but thought I'd share.
Yes, my MBZ does that, but it is from the bottom of the car... this is from the headlight, you can put your ear by it and it come from right behind the light... The fans are designed to keep the lights cool and extend the life of the headlight. At the dealer (non-warranty) they are about $1900 each.
Here are headlamp related schematic. One shows the internal fan (note the little fan symbol). The headlamps may or may not also have internal leveling (that will not be the source of the noise being discussed) - which is described extensively in the Service Manual. Headlamp assemblies are available with and without leveling in the on line parts suppliers. From the description in the Service Manual, I think that the leveling is part of the optional front lift system.
