Sponsored by: Wheel Design
C8 door issue
Old Sep 15, 2022 | 03:14 PM
tgkio1969's Avatar
tgkio1969
1st Gear
Default C8 door issue
My car is a non-Z51 Convertible C8, The issue is with the driver's door release sensor. At times the door will not open. I have use two methods to exit the car, 1st option, push the unlock button and then the door release button to exit, the other is to hit the door release button 3 - 4 times before the door will open. This can.t be normal as most of the time the door release works properly. Bad door release Sensor? ... any help will be appreciated.
Old Sep 15, 2022 | 03:29 PM
Avanti's Avatar
Avanti
Most likely off to the dealer... sorry.
Old Sep 15, 2022 | 03:31 PM
David.L's Avatar
David.L
What model year is your car?
Old Sep 15, 2022 | 04:11 PM
Zymurgy's Avatar
Zymurgy
Moderator
Press and hold the release button as you push the door open.
Old Sep 15, 2022 | 04:16 PM
Andybump's Avatar
Andybump
Don't know if its your issue, but many have encountered a problem that is solved this way:
Be sure that you are pressing outward on the door (gently, but nonetheless pressing) before you start to push the door open button. If the button is pushed with no pressure on the door, the latch will partially release but the door will not open. If that is not what is going on with you, then you may have an actual defect.
Old Sep 16, 2022 | 11:21 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
This^^^
Common complaint among new owners. It isn't the car, it's an operator problem.
Old Sep 16, 2022 | 11:44 AM
TKKRCats's Avatar
TKKRCats
Originally Posted by MarkMeHopeful
This^^^
I agree. I had the occasional door issue and I saw on a thread how to "properly" open the door, no more issues.
I do admit when it was suggested that the operator was the problem I didn't believe that was the problem.
To C8 door issue
