Sponsored by: Wheel Design
C8 Remote Start
Old Jan 11, 2023 | 09:18 AM
First timer C8's Avatar
First timer C8
Navigator
Default C8 Remote Start
Is a subscription to Onstar required for the key fob remote function to work? I tried to use it the other day and couldn’t make it start. Went to the manual and I believe I followed the instructions, but can’t make it work. Suggestions please?
This is a great source of info for the new kid. Thanks in advance!
Popular Reply
Jan 11, 2023, 10:54 AM
Crispins's Avatar
Crispins
Originally Posted by Newdude
No.
Press lock once, then press the remote start button twice. Don't hold it, just "press" "press".
Weird, all I do is press the start icon 2x.
I never lock the door first.
Old Jan 11, 2023 | 09:19 AM
Aviator's Avatar
Aviator
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
No Onstar required. Make sure the trunk and frunk and doors are closed when using remote start?
Old Jan 11, 2023 | 09:33 AM
VetteND's Avatar
VetteND
Also the system will not work if there is a check engine light.
Old Jan 11, 2023 | 09:43 AM
proeagles's Avatar
proeagles
Did you press the lock button first, then the start button twice? If the car was already locked, it should have started on the second press of the start button. Otherwise, you probably should have a dealer look at it
Old Jan 11, 2023 | 09:55 AM
Newdude's Avatar
Newdude
No.
Old Jan 11, 2023 | 10:54 AM
Crispins's Avatar
Crispins
No.
Old Jan 11, 2023 | 11:25 AM
The procedure should be outlined in your owner’s manual. I do believe you have to press the lock button on the fob first then the remote start button twice.
Old Jan 11, 2023 | 12:08 PM
Red08's Avatar
Red08
Read your owners manual
Old Jan 11, 2023 | 12:21 PM
z51vett's Avatar
z51vett
My car auto locks remote start from inside house to heat or cool before I leave
Old Jan 11, 2023 | 03:53 PM
proeagles's Avatar
proeagles
Old Jan 11, 2023 | 05:33 PM
z51vett's Avatar
z51vett
I have car set to lock when I leave it parked at home or away
Old Jan 11, 2023 | 07:10 PM
jagtoes's Avatar
jagtoes
If the doors are locked then press button twice. If the doors are unlocked press door lock the buttion twice.
Old Jan 11, 2023 | 07:36 PM
Andybump's Avatar
Andybump
Just checked this. On my 2021 I can just push the start button twice. Mine does not have to be locked. But you can lock it first if that is what you want. There is a list items that will prevent the remote start from working.
Old Jan 11, 2023 | 09:10 PM
Red Mist Rulz's Avatar
Red Mist Rulz
I never press the lock button first, and the car is unlocked if it's in my garage.
Old Jan 11, 2023 | 09:42 PM
Crispins's Avatar
Crispins
I already mentioned it once but I will mention it again as it seems to be unclear.
I never lock my car, never.
I press the start button 2x and it starts right up.
I do it all the time.
No need for it to be locked, no need to press lock first.
Just 2x on the start button
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
I just hit the start button twice. No need to press lock button.
Old Jan 11, 2023 | 10:04 PM
john91498's Avatar
john91498
There's an item missing: Both doors need to be securely closed.
My wife borrowed my Corvette to cruise the beach with her sister. I got my car back, but didn't know the passenger side door was not fully closed and remote start wouldn't work. Went over the list above and she still would not remote start. Took her to the dealer and the service manager opened and closed the frunk, trunk and both doors. The remote started her right up. I felt dumb...
To C8 Remote Start
Old Jan 11, 2023 | 11:22 PM
proeagles's Avatar
proeagles
That's nice but it's not germane to the issue the OP has remote starting his car. As others have stated the car will start if the button is pressed twice while the car is locked.
Old Jan 11, 2023 | 11:43 PM
Crispins's Avatar
Crispins
OR UNLOCKED!!!!!!!!!!!
Have I not written in simple to understand words?
I have clearly written not once but twice that the car will start unlocked, why the hell are you saying otherwise?
I do not lock my car ever, and I remote start it everyday that I drive it.
Old Jan 12, 2023 | 12:28 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
^^^ I agree - mine is a 2022 HTC - I don't lock it and the remote start works just fine. Make sure the other conditions are met (see @Andybump post #13)
