Air filter
Don't use oils, chemicals or cleaning kits. Otherwise you will absolutely ruin the filter.
Aftermarket CA Intakes are interesting. Funny with all of the real engineering that goes into a high performance car's intake (so it is NOT the gate to airflow), that immediately after introduction along comes a whole group of aftermarket companies claiming to have beaten the factory engineering team. This is the same with EVERY high performance car manufacturer out there - Porsche, AMG, BMW, Mustang, Corvette, Camaro, Lamborghini, Ferrari, Aston Martin, Dodge, Plymouth, etc.
Ask yourself - why are ALL these engine designers so lame they cannot get an intake system done? And yes, agree with @dohabandit, funny how the performance numbers are always just enough to be "under the radar" so to speak. Not enough gain to really feel it, not enough gain to challenge it if you feel you didn't get the 10hp. It's low hanging fruit in the aftermarket, right next to exhausts.
In a way, I don't begrudge these companies for selling their wares. It's entrepreneurial, it's the American way, and as long as the buyer feels it in the butt dyno (where there is a direct correlation to the butt wallet - the more spent, the more power can be felt), I'm glad they're making money and employing people.
"High performance Air Filter" Is a misnomer.
You are likely to believe that it has something to do with increasing power, but actually a high performance filter will maintain or reduce power, because it filters more effectively and improves PCV action at WOT by providing a pressure drop.
If removing the filter or installing a less restrictive filter increases power above OEM due to mitigating pressure drop, it would reduce PCV WOT function for non-dry sump engines and reduce the life expectancy of the engine.
For example here is a C8 with a procharger run twice in a row.
When we are + and minus hp from environmental conditions, temperature, viscosity, etc... basically 3 or 4% of wheel horsepower (5% bhp~)
(remember higher temp = lower viscosity = more power delivered)
These factors interplay in a way that cannot be accounted for on the basis of just 5 or 10hp.
In other words, I wouldn't sacrifice or even risk the quality or longevity of an engine over 5 or 10hp. There is hp coming and going due to temperature related variables. Not to mention friction and situational basis as tire compound (different tires react to heating differently) and road conditions (not all surfaces are equivalent even on a track on the same day) which further plus or minus final tire force and energy transfer, these are normally negligible considerations but on the basis of 5hp or 10hp they are worthwhile in magnitude since we are discussing 5hp and 10hp differences, those variables as viscosity and friction are in that range of gain and loss.
1. All engine crankcase needs to see a vacuum at wide open throttle, however slight, 0.5" Hg is typical
2. The OEM develops their air cleaners with a specified, intentional pressure drop over some mileage which can promote crankcase evacuation
All OEM does this, from Toyota Corolla to Nissan Altima to Honda whatever, there is an intentional design plan for promoting high mileage and crankcase cleaning action on behalf of the PCV system and it's units are on the magnitude of 0.5" Hg or fractions of a PSI, easy to disrupt from leaking and modifications.
The pcv system is easy to disrupt. Air filters are notoriously easy to sell and install and the engineers of the original intake system went through great lengths to develop a system which they are confident will protect the engine.
I am reminded of a post I read once
You cannot trust any retailer or anyone who says their product or modification has made quantum leap. The mentality found here is far from being constructive.... and its only gotten worse
https://www.corvetteforum.com/forums...post1604771349
I think 3 to 5 hp is negligible. You can run the car back to back on a dynometer and see a similar or larger loss.
What I am confident for
When aftermarket air filters advertise themselves for " performance" increase they are almost always referring to a flow improvement or restriction reduction. They don't tend to care about increasing filtration over oem nor do most any claim do (because they don't)
The downside to this flow improvement is almost always reduced filtration (in which 4 layer oiled cotton gauze as well as dry synthetics will most certainly do). But how much filtration you need to keep the engine free of damaging silicates for 50k or 100k or 400k miles is debatable and also variable considering environmental factors.
Nonetheless there should be zero need for pcv modification. As you pointed out the difference in flow and power between a stock paper filter and even a gigantic and extremely low restriction single layer synthetic is probably 5hp or a minimal amount of kg/h air volume that would be exceeded in multiples by just driving the same car with the same hardware in 40f sea level density altitude to taking it to 100f 6000 foot altitude. The vehicles SAI and PCV system is already designed to operate within that very significant variance in pressure and much more.
With an NA engine the laws of physics play a clear part. An NA engine can only ingest a maximum volume of air based on these laws. Air intake need on the LT2 is not infinite.
A formula that I think is simple enough to convey the message is - Airflow (in CFM) = (HP x 0.625) x 1.1104.
If I apply it to the LT2 at 495 hp I get (495 x 0.625) x 1.1104 = 343.53 CFM to satisfy this engine's air volume intake needs.
I'm making an assumption here, I cannot imagine the engine design team created an intake that would fall short of the need to flow 344 CFM of air to feed this engine of all the CFM it can use. That includes the filter element and the charge tubes, intake manifold, etc. If I am wrong, then there MIGHT be merit to an aftermarket "filter" that flowed better or was less restricted.
On an engine which I have a lot more practical "hands on" experience, the 4.0L Hot V engine (an FI engine) used in the MB AMG GT, GTS, GTR, GTR Pro, GTR BS, and beyond, The stock air intake system (and filters) is the same used on all these models:
GT - 456hp
GTS - 505hp
GTR- 550hp
GTR Pro - 575hp
GTR BS 720hp
And at least one aftermarket build of 1100hp 4.0L Hot V using the factory air intake system. So, assuming the AMG factory engineers designed an intake system to flow enough volume to satisfy all of these HP ranges and beyond, some "naive" owners of GTs and GTSs fall for the aftermarket intakes that cost well into the $thousands, and cut off the factory one BC slick marketing leads them to believe the aftermarket really caught the AMG engineering team sleeping and their aftermarket intakes offered more air flow, or less restriction.
GT - 456hp
GTS - 505hp
GTR- 550hp
GTR Pro - 575hp
GTR BS 720hp
Maybe, maybe not. ... Probably
The important thing to note is we cannot make any extrapolations from another platform.
The only way to determine our air intake systems efficiency and efficacy is through complex modeling and ultimately rigorous controlled condition testing.
Sometimes a filter element helps improve powe a bit. Sometimes it doesn't.
Sometimes the airbox itself had a volumetric limitation. Sometimes it doesn't
Sometimes the flow path is not optimized. Sometimes it is.
Sometimes the intake temps get influenced negatively by intake routing or design, sometimes they dont, or sometimes an oem mitigation technique is used and works.... sometimes it partially works, sometimes it doesn't work much.
But yes in a perfect engineering world merely changing the filter "shouldn't" free up much power but of course we don't live in a perfect engineering world.
