Sponsored by: Wheel Design
Frunk Hood Material ?
Old May 15, 2023 | 08:20 AM
Walt White Coupe's Avatar
Walt White Coupe
Default Frunk Hood Material ?
Does anyone know if the frunk hood material is normal body panel fiberglass or carbon fiber? I would like to put my E-Zpass transponder in the frunk but I know from my C7 that carbon fiber will not pass its signal. Has anyone put their transponder in the frunk?
Old May 15, 2023 | 11:59 AM
sanddigger's Avatar
sanddigger
2024 C8 of the Year Finalist - Modified
yes......works just fine
Old May 15, 2023 | 12:00 PM
johnodrake's Avatar
johnodrake
Moderator
The hood panel is SMC (sheet moulding compound) same as the fenders, etc.
Old May 15, 2023 | 12:07 PM
tadda's Avatar
tadda
Veteran: Marine Corps
So what actual "material" is it made of? That was the OP's question and I'm curious as well!
Old May 15, 2023 | 12:59 PM
C5racecar's Avatar
C5racecar
SMC = glass-fibre reinforced polyester material. It is basically the same material as fiberglass, but not liquid and cloth, it comes in sheets, ready to apply heat and form into a mold. If the frunk was carbon fiber, that would be an option you would have to pay for.
Old May 15, 2023 | 02:15 PM
Rapid Z's Avatar
Rapid Z
Glass re enforced plastic that is pressed in a mold more or less. All C7s had 100% C/F hoods C8 does not.
Old May 15, 2023 | 02:44 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Molded Fiberglass Company makes some of the composite body panels for the C8's. They were the ones who got GM started in fiberglass for the 1st 1953! In the Museum there are pics of Robert Morrison the founder of the company who Chevy credits for the innovation. Today Molded Fiberglass only make the more expensive, very light products that have a density less that water. They float. But the standard body panels are close to a density of 1 (water.) They typically are ~40% fiberglass with polyester reasons and a filler. That filler is now hollow glass microbeads to provide the light weight.
My wife and her brother brother lived down the street from Robert Morrison and he recalls going for a ride in Morrison's 1953!
SIDEBAR
Corvette Body Materials
Fiberglass isn't the primary body material on Vettes these days, but the car continues a tradition of non-traditional, lightweight bodywork that began with the very first one off the assembly line in 1953. In fact, the reason conventional fiberglass isn't used any longer is because it's been replaced with better, lighter composite materials.
Old May 15, 2023 | 03:47 PM
WhiteDevil828's Avatar
WhiteDevil828
2025 C8 of the Year Finalist - Modified
I placed my EZPass at the very front of the frunk and have had no issues in 2 months. Tag has been read with every pass.
Old May 15, 2023 | 04:20 PM
Walt White Coupe
Thanks so much for everyone clearing that up. I was hoping I could use the Frunk for my E-ZPass.
Old May 15, 2023 | 08:13 PM
Zymurgy's Avatar
Zymurgy
Moderator
As already stated, it is SMC (Toughened SMC Class A bonded and painted) per the following: https://www.compositesworld.com/arti...orvette-part-2
Old May 15, 2023 | 08:42 PM
NJMikeC8's Avatar
NJMikeC8
2023 C8 of the Year Finalist - Modified
I also have my EZ-Pass mounted in the frunk, only difference being that it is at the edge nearest the windshield. No issues in over 6 months.
Old May 15, 2023 | 09:00 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
I believe Everyone that says it worries fine, but how do you test it? Just drive thru and hope?
Old May 15, 2023 | 09:06 PM
Walt White Coupe
Sounds to me like the testing has already been done and that's good news. The C6 with the same fiberglass worked fine.
Old May 15, 2023 | 11:34 PM
Sounds like you will be fine with the transponder in the frunk.
Old May 16, 2023 | 07:41 AM
JerryU's Avatar
JerryU
Yep that Link shows the material I mentioned that floats made by the folks who got GM started with fiberglass, Molded Fiberglass (MFG) in Ashtabula OH:
Body structure: part B
"The new Corvette features not one but two trunks that, combined, hold 12.6 cubic-feet/0.36 cubic meters of cargo. Both trunks are produced in 42 wt-% chopped fiberglass/vinyl ester-unsaturated polyester (VE-UP) resin, but use different processes driven by geometry and mechanical requirements. The front trunk (frunk) is compression molded 0.95-specific gravity (SG) “float” sheet molding compound (SMC), while the rear trunk is formed via the proprietary PRiME (Prepositioned Reinforcement ensuring Manufacturing Excellence) process, a liquid compression molding (LCM) variant. The float SMC and the PRiME process were developed by processor Molded Fiber Glass Co. (MFG, Ashtabula, Ohio, U.S.). MFG produced all structural SMC and LCM’d parts on the car."
Note, as that article states most body panels:
Exterior body panels are all bonded (inner/outer), painted, toughened 1.2-SG SMC (22-28% FVF fiberglass/UP resin, depending on component) from Continental Structural Plastics (CSP), a Teijin Group company (Auburn Hills, Mich., U.S.). Note even a lower % fiberglass content!
Still have friends in Ashtabula (where I managed and R&D Lab.) One own's another molded fiberglass products company said the higher volume body panels are not sufficiently profitable for MFG to consider investing in the added capacity to manufacture.
Old May 16, 2023 | 08:13 AM
C8J's Avatar
C8J
Simple forum search and you will find
On a serious note, look here.
https://www.corvetteforum.com/forums...te-status.html
Old May 16, 2023 | 10:32 AM
JerryU's Avatar
JerryU
That article was not only interesting and informative it made me think how these densities relate to other structural materials. Since Specific Gravity is not Top of Mind for most (including me) I made this table for comparison!
Picked Iridium as it's one of the densest, highest specific gravity materials and it's used for some spark plug center electrodes.
Old May 16, 2023 | 11:20 AM
Fast Dawg's Avatar
Fast Dawg
Interesting thread. When I lived in Illinois I had the big plastic EZ Pass that I needed to drive around Chicagoland. When I moved back to Georgia and got a PeachPass it's just a piece of tape with a metal strip in the middle of it that you attach just under the rear view mirror. You can't see it when you are driving and it barely shows when you are outside the car looking at the windshield. You almost have to be looking for it to spot it.
To Frunk Hood Material ?
