Sponsored by: Wheel Design
Windshield replacement problem
Old May 21, 2023 | 01:44 PM
automaticj5's Avatar
automaticj5
Default Windshield replacement problem
Hello all!
I just had my windshield replaced with an OEM windshield. I've given it a month to dry and noticed where it says TEAM CORVETTE in the bottom corner - I noticed it only says TEAM CO and the rest is black and barely visible. I assume it's whatever they use to glue the windshield in.
Question is - is there anything I or they can do to clear the rest of the CORVETTE out? Without replacing again.
Old May 21, 2023 | 03:08 PM
Avanti's Avatar
Avanti
More important, is it water-tight? If so, stub your toe on something to take your mind off it; while recovering get in the car and go for a drive and never think about it again.
Old May 21, 2023 | 03:28 PM
automaticj5
it's water tight yes - and I could try to forget about it but everytime I clean my car I'll see it. And I'll be annoyed because it's not right and looks tacky.
Old May 21, 2023 | 03:35 PM
proeagles's Avatar
proeagles
Someone will correct me I'm sure but there is no way the glue is hiding that problem. Those letters, while part of the design, should have a black coating underneath them which the glue is applied to securing the windshield. If anything, it's a defective OEM windshield and I would bet that it looked that way before installation.
Old May 21, 2023 | 03:36 PM
4thC4at60's Avatar
4thC4at60
Old May 21, 2023 | 03:41 PM
Sunwarrior's Avatar
Sunwarrior
Defect, replace glass again
Old May 21, 2023 | 04:17 PM
If something is covering the lettering, go back to the glass company and ask them if they can clean the area so you can fully see the Corvette name.
Old May 21, 2023 | 04:39 PM
Zymurgy's Avatar
Zymurgy
Moderator
Wrong. Many have put a colored piece of paper behind that spot to colorize the Team Corvette.
OP, see if you can slip a piece of paper between the windshield and the Team Corvette area. You should be able to:
If not, they've got something there that should not be there.
Old May 21, 2023 | 04:47 PM
automaticj5
you hit it on the head right there - that's exactly what I do too - but can't cause it won't go down there.
Old May 21, 2023 | 04:51 PM
SMOKN C8's Avatar
SMOKN C8
Time for them to replace it again
Old May 21, 2023 | 06:20 PM
papillion's Avatar
papillion
Default Ocd
To see ours, I need to be within 6". Wearing my cheaters, angled just right, and using a flashlight. If I was the vendor and you ask to have it replaced again, I charge you for it.
Old May 21, 2023 | 06:37 PM
automaticj5
I'm not even sure what you are talking about. TEAM CORVETTE is at the bottom of all the new OEM windshields. You don't need to wear any glasses, it's obvious. Sorry you are blind? Can't charge me for a terrible install.
Old May 22, 2023 | 08:28 AM
proeagles's Avatar
proeagles
I'm glad I was wrong about that but then that is also a dumb design in my opinion. If you can slip a piece of paper down there then it seems dust/debris could collect there as well and that would look really special.
Old May 22, 2023 | 08:50 AM
Red Mist Rulz's Avatar
Red Mist Rulz
A photo of the problem would help a lot.
Old May 22, 2023 | 10:34 AM
SMOKN C8's Avatar
SMOKN C8
Agree, a picture would help but sure sounds like they were heavy handed on the applicator gun
Old May 22, 2023 | 10:36 AM
stvdman's Avatar
stvdman
Veteran: Coast Guard
I bet the black "goo" is covering the "RVETTE".
Old May 22, 2023 | 11:25 AM
Zymurgy's Avatar
Zymurgy
Moderator
Did you figure that out all by yourself? LOL.
To Windshield replacement problem
Old May 22, 2023 | 11:42 AM
stvdman's Avatar
stvdman
Using my extreme powers of deductive reasoning!!!!
Old May 22, 2023 | 01:56 PM
automaticj5
here's the pic
Old May 22, 2023 | 02:05 PM
Fast Dawg's Avatar
Fast Dawg
Take it back to whoever installed it, tell them what you've told us, and see if they can explain why you can't see the rest of the lettering.
