Sponsored by: Wheel Design
Hot Trunk
Old Aug 10, 2023 | 03:05 PM
  #41
See8's Avatar
See8
I have a 2022 HTC. Last month I drove on a trip that was over 3 1/2 hrs straight. Got home and removed my suitcase with clothes and dopp kit immediately and tossed my clothes in the laundry. Everything was completely the same as if it was in the trunk of my BMW. Absolutely none of it was warmer than room temperature.
Old Aug 11, 2023 | 07:14 AM
  #42
Ystayhm's Avatar
Ystayhm
Originally Posted by GDeanBlakely
I think it was the Car & Driver test where they were complaining about the hot trunk on the C8 seeing that it is next to the engine and above the exhaust. How bad is it? How hot does it get? I'm surprised the corvette engineers couldn't find a way to get an A/C duct to it. Any solutions?
There were a couple of U-tube videos showing outside temp at 30 degrees and trunk going into the 90's and in the 90's going to 138 degrees
TKOPerforamce has a heat shield they say will cut the heat rise by 30 degrees.
installed in my Coupe and my temp rise tends to stay under 30 degrees; using a TempStix to measure heat rise
Old Aug 11, 2023 | 08:08 AM
  #43
plmmd's Avatar
plmmd
Originally Posted by TD20
The trunk has kept all my to go food warm. Pizza also!
Did you put the pizza in standing on end? That would make a calzone with sauce
Wait I forget the rest of the world doesnt have real pizza like NY- Probably one of those gluten free non gmo vegan personal pies might fit- but who would want to eat it
Old Aug 11, 2023 | 01:45 PM
  #44
Red Mist Rulz's Avatar
Red Mist Rulz
Trunk temps aren't really a problem while you're moving. It's when you park, and the trunk gets heat soaked from the engine and exhaust. Trunk insulation will only slow heat transfer into the trunk, it won't eliminate it.
Old Aug 11, 2023 | 05:11 PM
  #45
Ystayhm's Avatar
Ystayhm
well the measurements showed about a 60 degree increase while moving so it would be worse with your heat soak when u stop
Old Aug 12, 2023 | 12:30 PM
  #46
JB23's Avatar
JB23
Banned Scam/Spammer
Originally Posted by Chemdawg99
@GDeanBlakely
I have the fitted luggage for the C8 and I think as long as you have good leather bags, you don't have to worry that your stick deodorant is going be a melted mess after a road trip, though it doesn't hurt to keep toiletries in the frunk as opposed the trunk.
I've searched for "the fitted luggage" and there are too many sites all saying "official c8 luggage" yet they're different. Do you have a link to what you purchased? Did you purchase direct from GM? Thanks.
Old Aug 12, 2023 | 01:34 PM
  #47
See8's Avatar
See8
Im guessing you have a coupe.
Starting to think this may be a coupe issue. My HTC trunk doesn’t heat the contents up at all.
Old Aug 12, 2023 | 05:43 PM
  #48
pk2401's Avatar
pk2401
St. Jude Contributor
I would say it's quite warm. Took my new C8 to the golf course this past week. About a 45 minute drive. I keep a bottle of whisky in my bag for birdie celebrations. Birdied number 2 and the high temp ruined my drink.
Old Aug 15, 2023 | 08:11 PM
  #49
Thunder22's Avatar
Thunder22
nope, happened in my c8 htc and now my c8 htc z06
Old Aug 16, 2023 | 04:32 PM
  #50
C8forT's Avatar
C8forT
Originally Posted by A10Beav
You can remove the cover to access the air filter and place a heat shield on the inside of it. I put a reflective barrier, but it only helped a little. I’d recommend a thin insulation pad with a reflective barrier on it.
The trunk isn’t extremely hot, but I wouldn’t keep the milk or ice cream back there.
I experimented with a thermal barrier, but it did not do much. I ended up pulling it out. See the following thread for my results and speculations based on those results.
https://www.corvetteforum.com/forums...at-shield.html
Old Aug 16, 2023 | 05:05 PM
  #51
Ystayhm's Avatar
Ystayhm
TKOPerformance has a kit which has the silver foil and pad backing
i've found by using a TempStix to monitor trunk heat that once installed it limits trunk temperature increase to sbout 30 degrees over the outside temp. A reduction of about 30 degrees from what it would hit
HTC is an easy install. Couple requires the removal of the storage brackets so takes a little longer
Old Aug 16, 2023 | 08:37 PM
  #52
GatorGreg's Avatar
GatorGreg
Here’s a great interview with Tadge wherein he acknowledges around the 2:15 mark that airflow and thermal were the biggest challenge in engineering the C8 since they wanted room for luggage and the roof in the back. After watching this I’m grateful that the C8 has a trunk at all and I will quit complaining that it gets a little hot especially since it has a frunk too.
Old Aug 17, 2023 | 02:36 PM
  #53
airforcex's Avatar
airforcex
Cold stuff in the front, anything else in the back. To me, the rear trunk is a bonus.
Old Aug 17, 2023 | 02:50 PM
  #54
Deepdiver's Avatar
Deepdiver
i installed some Thero-tec (
Link Link
) and I also keep a soft sided cooler in the trunk for those unexpected trips to the grocery store on the way home from (insert location). It's worked out well and I have no complaints.
Old Aug 17, 2023 | 04:11 PM
  #55
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
I purchased directly from GM using my points.
You can (and should) either order through your dealership or using the MyChevy app. Be forewarned that these bags are pricey, about $700 a piece, but are quality. Two bags fit in the rear trunk and one in the front trunk. You only really need two for the rear trunk.
Old Nov 12, 2025 | 09:10 PM
  #56
Curtis517's Avatar
Curtis517
5th Gear
Default Insulting
I bought from Amazon one roll of
Brand: US Energy Products Brand: US Energy Products
Double Bubble Reflective Foil Insulation (24 inch X 10 Ft Roll). Cut roll into two 10ft pieces. Then ,when I changed the engine air filter I installed one layer along the front part of trunk and along the base of trunk. Then I tapped the second piece about half way down the front of the trunk. Making two layers on half the front of trunk and bottom. Cut 3 inch holes for reattaching the cargo net hangers that hold the trunk liner in place.
This made my trunk very close to the normal temp of a normal trunk. This material is like the bubbled windshield sun protectors.
Old Nov 12, 2025 | 09:15 PM
  #57
Ystayhm's Avatar
Ystayhm
I used a freezer thermometer with WiFi capabilities; Foing what has been described in this listing was able to cut heat run up by 40 degrees
To Hot Trunk
Old Nov 20, 2025 | 05:17 PM
  #58
CZƐCH M8's Avatar
CZƐCH M8
mine isn't bad at all and I put on new exhaust that doesn't have any heat shields.
Old Nov 20, 2025 | 06:28 PM
  #59
PurdueDoc's Avatar
PurdueDoc
Originally Posted by Curtis517
I bought from Amazon one roll of Brand: US Energy Products Double Bubble Reflective Foil Insulation (24 inch X 10 Ft Roll). Cut roll into two 10ft pieces. Then ,when I changed the engine air filter I installed one layer along the front part of trunk and along the base of trunk. Then I tapped the second piece about half way down the front of the trunk. Making two layers on half the front of trunk and bottom. Cut 3 inch holes for reattaching the cargo net hangers that hold the trunk liner in place.
The link just goes to Amazon, not the product.
Old Nov 21, 2025 | 12:03 PM
  #60
RogerTheDodger's Avatar
RogerTheDodger
St. Jude Donor '08
We stored a bottle of red wine in the trunk on a 3 hour trip, got to destination and the cork was half way out because of the heat. Now we store in the frunk. Always something new to learn in life.LOL
