Sponsored by: Wheel Design
Security camera/ Dash camera for C8
Old Jul 25, 2023 | 08:36 AM
monkswagger's Avatar
monkswagger
Default Security camera/ Dash camera for C8
HI, everyone!
I just picked my C8 up on July 1st and thinking about getting a security camera.
I do use built-in drive recorder while driving but when I park my C8 on a street or public garage I kinda get nervous all the time.
So main reason for getting a security camera is to feel safe when my C8 is parked on a street or public garage. BUT of course it can be used as a secondary drive recorder. (As I mentioned I used a built-in drive recorder while I'm driving)
I did spent so much time on researching it but can't find the right one. If you guys have some good idea please let me know.
Thank you in advance.
Monkswagger
Old Jul 25, 2023 | 10:54 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Moved out of detailing section gl
Old Jul 25, 2023 | 11:26 AM
scithera's Avatar
scithera
I run a Blackvue DR900X 2 channel system. You can run it with a battery backup for parking mode so you don't drain your car battery. Been very happy with Blackvue dash cams.
Old Jul 25, 2023 | 11:28 AM
sandmark's Avatar
sandmark
where do you mount the second camera on the Blackvue?
Old Jul 25, 2023 | 11:31 AM
monkswagger
Thank you for sharing your thoughts. I'll look at it
Old Jul 25, 2023 | 01:16 PM
barturo61's Avatar
barturo61
ring makes a dash cam security cam
Old Jul 25, 2023 | 05:18 PM
scithera's Avatar
scithera
Top center of the inside rear window.
Old Jul 25, 2023 | 06:26 PM
sandmark's Avatar
sandmark
Does it interfere with the view in the normal rear view mirror? If you could post a pic of it mounted , that would be great
Old Jul 25, 2023 | 08:47 PM
scithera's Avatar
scithera
It does not. You can look at the video from this post. . .I set mine up similarly: https://www.corvetteforum.com/forums...d-footage.html
Old Aug 12, 2023 | 04:33 PM
pgp's Avatar
pgp
Look into the Viofo A119v3. It's a single channel but I think they have a duel one too.
Amazon:
Amazon Amazon
Old Aug 12, 2023 | 06:07 PM
kostof's Avatar
kostof
Cruising
I have a Garmin Dashcam Mini 2 attached to the windshield just to the right of the overhead console where I can't see it from the driver's seat. Then I've got an OBD-II port adapter to keep it running after I stop the car. But I bought that adapter before I'd taken delivery and didn't realize the diagnostic port was located where I'd occasionally kick the adapter. So I'm considering installing a simple battery adapter instead.
Whatever you get it's probably a good idea to make sure it has a polarized lens, or at least the option to attach one since you'll get a lot of reflections off the dash.
Old Aug 12, 2023 | 07:50 PM
scithera's Avatar
scithera
Originally Posted by pgp
Be careful with the Viofo's. I have an A129 Pro Duo 4K in my wife's Outback and it will overheat and restart at times. Doesn't handle the heat as well as my Blackvue units.
Old Aug 12, 2023 | 08:17 PM
IrishSpuds's Avatar
IrishSpuds
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
The ring and junky chinese cheap ones are all crap. You will pay hundreds for a decent one and backup battery. Get it professionally installed. I have cams in four of my vehicles, all professionally installed (don’t want wires hanging down or plugged into the cigarette adapter). I don’t have battery backup as I’m ok with parking, I only care about ******** driving, thus I have 3 channel cameras. Get the full Blackvue setup.
Old Aug 13, 2023 | 12:56 AM
Thanks for the recommendations. Been thinking about one for my C7.
Old Aug 13, 2023 | 12:58 AM
Garret's Avatar
Garret
I believe in the Beer Fairy
https://dashcamtalk.com/
To Security camera/ Dash camera for C8
